주요 콘텐츠로 건너뛰기
Datawind Ubislate 7ci Battery Replacement
필요한 것
  1. Datawind Ubislate 7ci Battery Replacement, Battery: 1 단계, 이미지 1/2 Datawind Ubislate 7ci Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • Be careful of the device's small wiring when separating the two halves.
  2. Datawind Ubislate 7ci Battery Replacement: 2 단계, 이미지 1/3 Datawind Ubislate 7ci Battery Replacement: 2 단계, 이미지 2/3 Datawind Ubislate 7ci Battery Replacement: 2 단계, 이미지 3/3
    • Remove the black tape.
    • Be careful not to remove the tablet camera.
  3. Datawind Ubislate 7ci Battery Replacement: 3 단계, 이미지 1/3 Datawind Ubislate 7ci Battery Replacement: 3 단계, 이미지 2/3 Datawind Ubislate 7ci Battery Replacement: 3 단계, 이미지 3/3
    • Use a soldering iron to remove the battery from both its attachment points.
    • Pry off the battery using an opening tool.
  4. Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: 4 단계, 이미지 1/2 Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: 4 단계, 이미지 2/2
    • Insert your replacement battery in the same spot as the old battery.
    • Tape battery into place.
  5. Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: 5 단계, 이미지 1/2 Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: 5 단계, 이미지 2/2
    • Solder the new battery to the connection points.
    • Press the back cover on firmly until it clicks.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Mekides
회원 가입일: 10/20/14
40 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G3
3 회원들
안내서 6개 작성하였습니다
댓글 2개
On my 7Ci the battery is SFH-HLKJ-204.
Datawind doesn't sale those pieces.
Where can I find one?
What type is it, voltage and so?
THX!
ylco - 답글
3.7V, 2200mAh lithium ion. Yiu can get a bigger or smaller one depending on shat you want.
Jessica Parnelli Fawkes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 16
전체 시간: 9,034
