주요 콘텐츠로 건너뛰기
Datawind Ubislate 7ci Rear Facing Camera Replacement
필요한 것
  1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Finding a work space: 1 단계, 이미지 1/1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: 2 단계, 이미지 1/2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: 2 단계, 이미지 2/2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves.)
  3. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: 3 단계, 이미지 1/2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: 3 단계, 이미지 2/2
    • Remove the black tape that is circled.
    • The camera is circled in this picture.
  4. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: 4 단계, 이미지 1/2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: 4 단계, 이미지 2/2
    • Carefully remove the camera from its housing.
  5. Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: 5 단계, 이미지 1/2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: 5 단계, 이미지 2/2
    • Slide the new camera into its housing carefully.
    • it should look like the second picture when you are finished
  6. Datawind Ubislate 7ci Rear Facing Camera Replacement, Closing the Tablet: 6 단계, 이미지 1/1
    • Press the back cover of the tablet on firmly until it clicks
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mekides
회원 가입일: 10/20/14
40 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 10
전체 시간: 293
