주요 콘텐츠로 건너뛰기
Datawind Ubislate 7ci Speaker Replacement
필요한 것
  1. Datawind Ubislate 7ci Speaker Replacement, Finding a workspace: 1 단계, 이미지 1/1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: 2 단계, 이미지 1/2 Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: 2 단계, 이미지 2/2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated, your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves)
  3. Datawind Ubislate 7ci Speaker Replacement, Removing the speaker: 3 단계, 이미지 1/1
    • Use your prying tool to pop the speaker out from its housing.
  4. Datawind Ubislate 7ci Speaker Replacement, Detach from contact points: 4 단계, 이미지 1/1
    • Use a soldering iron to remove the speaker from its contact points.
  5. Datawind Ubislate 7ci Speaker Replacement, Attaching replacement to contact points: 5 단계, 이미지 1/1
    • Solder your new speaker to the same contact points as before.
  6. Datawind Ubislate 7ci Speaker Replacement, Housing the replacement speaker: 6 단계, 이미지 1/1
    • Apply a small amount of adhesive to the new speaker, and place it into the housing on the back panel.
  7. Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: 7 단계, 이미지 1/2 Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: 7 단계, 이미지 2/2
    • Put the two halves back together.
    • Push down on the edges until you hear them click into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mekides
회원 가입일: 10/20/14
40 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 11
전체 시간: 287
