주요 콘텐츠로 건너뛰기
HTC Desire 510 Front and Main Cameras Replacement
필요한 것
동영상 개요
  1. HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: 1 단계, 이미지 1/3 HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: 1 단계, 이미지 2/3 HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: 1 단계, 이미지 3/3
    • Switch off the phone, remove the battery and any installed SIM and memory cards.
    • Remove 7x Torx T5 screws.
  2. HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: 2 단계, 이미지 1/3 HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: 2 단계, 이미지 2/3 HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: 2 단계, 이미지 3/3
    • Use a plastic tool to remove the rear bezel.
    • The loudspeaker is on the inner side of the rear bezel.
  3. HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: 3 단계, 이미지 1/3 HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: 3 단계, 이미지 2/3 HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: 3 단계, 이미지 3/3
    • Disconnect the touch screen flex cable.
    • Disconnect the light sensor flex cable.
    • Unstuck the vibra-motor from the middle frame.
    • Remove the coaxial antenna cable from the middle frame.
    • The LCD display flex cable is connected to the bottom side of the board.
  4. HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: 4 단계, 이미지 1/3 HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: 4 단계, 이미지 2/3 HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: 4 단계, 이미지 3/3
    • At the upper left side, the board is held by a plastic locking clip. Use a plastic tool and start the separating from here.
    • Gently disconnect the LCD display flex cable.
    • Now remove the logic board.
  5. HTC Desire 510 Front and Main Cameras Replacement, Front and Main Cameras: 5 단계, 이미지 1/2 HTC Desire 510 Front and Main Cameras Replacement, Front and Main Cameras: 5 단계, 이미지 2/2
    • Main / Rear camera.
    • New line.
결론
다른 2명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,647 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,498개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 1,565
