주요 콘텐츠로 건너뛰기
HTC One M8 Rear Case Replacement
필요한 것
  1. HTC One M8 Rear Case Replacement, SIM Card: 1 단계, 이미지 1/2 HTC One M8 Rear Case Replacement, SIM Card: 1 단계, 이미지 2/2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
    • Press to eject the tray.
    • This may require a significant amount of force.
  2. HTC One M8 Rear Case Replacement: 2 단계, 이미지 1/1
    • Remove the SIM card tray assembly from the HTC One M8.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  3. HTC One M8 Rear Case Replacement, MicroSD Card: 3 단계, 이미지 1/2 HTC One M8 Rear Case Replacement, MicroSD Card: 3 단계, 이미지 2/2
    • Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone.
  4. HTC One M8 Rear Case Replacement: 4 단계, 이미지 1/1
    • Remove the microSD card tray assembly from the HTC One M8.
    • When reinserting the microSD card, ensure that it is in the proper orientation relative to the tray.
  5. HTC One M8 Rear Case Replacement, Rear Case: 5 단계, 이미지 1/2 HTC One M8 Rear Case Replacement, Rear Case: 5 단계, 이미지 2/2
    • Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles.
    • Refer to the iOpener guide for info on how to use the iOpener.
  6. HTC One M8 Rear Case Replacement: 6 단계, 이미지 1/3 HTC One M8 Rear Case Replacement: 6 단계, 이미지 2/3 HTC One M8 Rear Case Replacement: 6 단계, 이미지 3/3
    • Use a plastic opening tool to gently peel up the lower speaker grille.
    • The adhesive is messy, and can be removed using Goo-gone.
  7. HTC One M8 Rear Case Replacement: 7 단계, 이미지 1/2 HTC One M8 Rear Case Replacement: 7 단계, 이미지 2/2
    • Use a plastic opening tool to gently peel up the upper speaker grille.
  8. HTC One M8 Rear Case Replacement: 8 단계, 이미지 1/1
    • Remove the two silver 3 mm Phillips #00 screws from the top.
    • Remove the four black 4 mm T5 Torx screws from the bottom.
  9. HTC One M8 Rear Case Replacement: 9 단계, 이미지 1/3 HTC One M8 Rear Case Replacement: 9 단계, 이미지 2/3 HTC One M8 Rear Case Replacement: 9 단계, 이미지 3/3
    • Work your way around the perimeter of the phone with a spudger and plastic opening picks to free the clips that secure the rear case to the display assembly.
    • A metal spudger is pictured, but it is best to use a nylon spudger to prevent marring the device.
    • Be careful not to lose the power button: it sits loosely in the top of the lower chassis.
    • Significant force may be required to pry the casing apart.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Michael Gonzalez
회원 가입일: 04/14/15
4,430 평판
안내서 5개 작성하였습니다
Cal Poly, Team 5-9, Maness Spring 2015 Cal Poly, Team 5-9, Maness Spring 2015 회원
CPSU-MANESS-S15S5G9
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 6,923
