주요 콘텐츠로 건너뛰기
HTC One Motherboard Replacement
필요한 것
  1. HTC One Motherboard Replacement, Front Panel: 1 단계, 이미지 1/1
    • Use the plastic opening tool to loosen the adhesive from the crease surrounding the screen.
    • The volume button is a good place to begin, it should come right out as you pry.
  2. HTC One Motherboard Replacement: 2 단계, 이미지 1/1
    • Wedge the plastic opening tool into the crack around the screen, on only the top, left and right sides.
    • Applying heat with the iOpener or a heat gun can speed this process.
  3. HTC One Motherboard Replacement: 3 단계, 이미지 1/1
    • Once the screen has been loosened on the top, left and right edges, lift the screen. It will remain attached at the bottom on a hinge.
    • The screen will remain attached to this hinge until the final step.
  4. HTC One Motherboard Replacement: 4 단계, 이미지 1/1
    • Carefully remove the volume button. Loosen the back panel of the phone with the plastic opening tool. Begin loosening and prying in the space where the battery was.
  5. HTC One Motherboard Replacement: 5 단계, 이미지 1/1
    • Once the crease has been loosened all around, pry the back panel open and lift until it can be removed.
  6. HTC One Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove tape to expose #000 screws, remove all screws.
    • Use the #000 bit screwdriver
  7. HTC One Motherboard Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Reach beneath the motherboard with the tweezers, grip it and lift.
    • Lift with care, the motherboard is not completely disconnected yet.
    • Remove the tape connecting the motherboard to the phone and gently lift it out.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Meghan
회원 가입일: 09/23/14
479 평판
안내서 1개 작성함
USF Tampa, Team 12-1, Blackwell Fall 2014 USF Tampa, Team 12-1, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S12G1
4 회원들
안내서 7개 작성하였습니다
댓글 2개
Where can I buy a motherboard to do the replacement?
Askateth - 답글
Will changing the motherboard fix the pink tint in my camera?
mmm50592 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 14,963
