주요 콘텐츠로 건너뛰기
How to Force Restart an iPhone 4S
  1. How to Force Restart an iPhone 4S, How to Force Restart an iPhone 4S: 1 단계, 이미지 1/2 How to Force Restart an iPhone 4S, How to Force Restart an iPhone 4S: 1 단계, 이미지 2/2
    • Press and hold the Home button.
    • While holding the Home button, press and hold the Sleep/Wake button.
  2. How to Force Restart an iPhone 4S: 2 단계, 이미지 1/2 How to Force Restart an iPhone 4S: 2 단계, 이미지 2/2
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
결승점
다른 233명이 해당 안내서를 완성하였습니다.
Evan Noronha
회원 가입일: 02/05/15
223,653 평판
안내서 168개 작성하였습니다
댓글 23개
what if our power butoon is broken/
Autumn Harris - 답글
Under settings, accessability, turn on assistive touch. You'll have a grey dot floating around on your screen. When you touch the dot, it brings up the full "menu." Touch "device" then a lock button option will show. Press and hold the lock icon. You'll then have the "slide to power off" option. Turn off. Give it a couple minutes. Don't panic, even without the working power button to turn it back on, it's still doable! Just plug the phone in and it'll power right on.
Heather Powers -
It worked, I can't believe this! Thank you so much, I tried everything I could think of to get it started. I put it in a bag of rice for 12 hours, a bed warmer, blow dryer, and nothing. I started looking for repair shop's, and stumble on your site, which included all iphones. I went to my phone model and the instructions said force start, and I tried it and presto, I'm back in business. THANK YOU! 724-309-3210
Dr Ed Day - 답글
Great Instructions! Thank you.
georgiaruocco - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 55
30일 전: 227
전체 시간: 84,835
