주요 콘텐츠로 건너뛰기
TiVo Series 2 TCD24008A Power Supply Replacement
필요한 것
  1. TiVo Series 2 TCD24008A Power Supply Replacement, Cover: 1 단계, 이미지 1/1
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Power Supply Replacement: 2 단계, 이미지 1/1
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Power Supply Replacement: 3 단계, 이미지 1/1
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Power Supply Replacement, Power Supply: 4 단계, 이미지 1/1
    • Locate the power supply.
  5. TiVo Series 2 TCD24008A Power Supply Replacement: 5 단계, 이미지 1/1
    • Remove the belt connecting the power supply to the motherboard by pulling it out.
  6. TiVo Series 2 TCD24008A Power Supply Replacement: 6 단계, 이미지 1/1
    • Remove the red, yellow, and black cable connecting the power supply to the hard drive.
  7. TiVo Series 2 TCD24008A Power Supply Replacement: 7 단계, 이미지 1/1
    • Remove the two 0.31 inch T-9 screws from the power supply.
  8. TiVo Series 2 TCD24008A Power Supply Replacement: 8 단계, 이미지 1/2 TiVo Series 2 TCD24008A Power Supply Replacement: 8 단계, 이미지 2/2
    • Pinch the plastic plugs and lift the power supply up to detach from plugs.
    • All 4 plugs must be detached to remove power supply.
결론
Phil Jones
회원 가입일: 10/11/11
41 평판
안내서 1개 작성함
Cal Poly, Team 5-33, Amido Fall 2011 Cal Poly, Team 5-33, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G33
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,211
