주요 콘텐츠로 건너뛰기
How to convert your Mac's storage from HFS to APFS file system
    • As a preventative measure, it is highly recommended you create an external backup drive to backup your files to
    • Typically converting your file system should not effect your data, but there is always a risk of loosing data when messing with the internal drive.
  1. How to convert your Mac's storage from HFS to APFS file system, Open Disk Utility and click on the View option: 2 단계, 이미지 1/2 How to convert your Mac's storage from HFS to APFS file system, Open Disk Utility and click on the View option: 2 단계, 이미지 2/2
    • Open the Disk Utility application and click the View option in the left hand corner.
    • From the drop down menu, choose the Show All Devices option from the list.
  2. How to convert your Mac's storage from HFS to APFS file system, Select the drive you want to convert: 3 단계, 이미지 1/1
    • You should see a list of all your containing drives within each of their respective volume. Select the drive you want to convert and click the Partition button from the buttons in the upper right hand side of the window.
    • Make sure your Scheme is set to GUID Partition Map
    • Depending on the drive you're converting, your Scheme may be set to the "MS-DOS" format. In this case you would need to change the partition format.
    • Select Mac OS Extended (Journaled) from the "Format" dropdown menu.
    • Make sure the settings are correct, and click the Apply button.
    • Right click on the partition you set, and select Convert to APFS.
결론
Congratulations! You have successfully converted your drive to APFS. As stated previously, your files should have not been touched, always make sure everything is correct.
다른 한 분이 해당 안내서를 완성하였습니다.
Jacob Mehnert
회원 가입일: 10/18/21
27,382 평판
안내서 43개 작성하였습니다
iFanatics iFanatics 회원
Community
54 회원들
안내서 156개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 19
7일 전: 138
30일 전: 688
전체 시간: 17,050
