주요 콘텐츠로 건너뛰기
Linksys WRT54GS v2 Antenna Ports Replacement
필요한 것
  1. Linksys WRT54GS v2 Antenna Ports Replacement, Front Case: 1 단계, 이미지 1/1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Antenna Ports Replacement: 2 단계, 이미지 1/1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Antenna Ports Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Antenna Ports Replacement: 4 단계, 이미지 1/1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  5. Linksys WRT54GS v2 Antenna Ports Replacement, Motherboard: 5 단계, 이미지 1/1
    • Slide the board unit out and up.
  6. Linksys WRT54GS v2 Antenna Ports Replacement: 6 단계, 이미지 1/1
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
  7. Linksys WRT54GS v2 Antenna Ports Replacement, Antenna Ports: 7 단계, 이미지 1/2 Linksys WRT54GS v2 Antenna Ports Replacement, Antenna Ports: 7 단계, 이미지 2/2
    • Turn the circuit board over and identify which solder connection you will desolder.
    • The solder connections shown in red hold the right antenna port in place. There is one more attachment for this antenna on the other side of the board.
    • The solder connections shown in blue hold the left antenna port in place. Desolder these 4 points to remove the antenna port.
  8. Linksys WRT54GS v2 Antenna Ports Replacement: 8 단계, 이미지 1/1
    • Turn on your soldering iron and allow it to get to its highest temperature setting (minimum 600ºF).
  9. Linksys WRT54GS v2 Antenna Ports Replacement: 9 단계, 이미지 1/1
결론
다른 2명이 해당 안내서를 완성하였습니다.
Allian Roman
회원 가입일: 10/12/11
276 평판
안내서 5개 작성하였습니다
Cal Poly, Team 3-4, Regan Fall 2011 Cal Poly, Team 3-4, Regan Fall 2011 회원
CPSU-REGAN-F11S3G4
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Most do not have removeable antennae ports
tom - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 3,256
