주요 콘텐츠로 건너뛰기
LG G3 - How to fix GPS not working
필요한 것
  1. LG G3 - How to fix GPS not working, LG G3 - How to fix GPS not working: 1 단계, 이미지 1/3 LG G3 - How to fix GPS not working, LG G3 - How to fix GPS not working: 1 단계, 이미지 2/3 LG G3 - How to fix GPS not working, LG G3 - How to fix GPS not working: 1 단계, 이미지 3/3
    • Shutdown your phone.
    • Remove the back cover of the phone
    • Unscrew all the screws identified in red in the picture.
    • Remove the plastic covers using your fingernails or a plastic tool.
  2. LG G3 - How to fix GPS not working: 2 단계, 이미지 1/1
    • Carefully peel off the 3 metal stickers (connectors) identified in white on the photo with a flat screwdriver.
    • Please note these stickers are fragile and can tear.
    • Cut pieces of a sheet of cardboard or a sheet thick enough to the size of the stickers.
    • Glue a piece of cardboard or thick paper under each sticker to create extra thickness.
    • Replace the stickers in their original location (they will no longer stick to the shell, but that's okay).
    • Reassemble the phone by repeating the previous steps, taking care to tighten the screws properly when reassembling
결론
To reassemble your device, follow the instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
draxx
회원 가입일: 02/08/19
175 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 1,960
