주요 콘텐츠로 건너뛰기
Mac mini Late 2012 Cowling Replacement
필요한 것
  1. Mac mini Late 2012 Cowling Replacement, Bottom Cover: 1 단계, 이미지 1/2 Mac mini Late 2012 Cowling Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
  2. Mac mini Late 2012 Cowling Replacement: 2 단계, 이미지 1/1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Mac mini Late 2012 Cowling Replacement, Fan: 3 단계, 이미지 1/1
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Mac mini Late 2012 Cowling Replacement: 4 단계, 이미지 1/1
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • Removing the standoff screw is not necessary to remove the fan. You need only raise the fan enough to lift it off the standoff screw.
  5. Mac mini Late 2012 Cowling Replacement: 5 단계, 이미지 1/3 Mac mini Late 2012 Cowling Replacement: 5 단계, 이미지 2/3 Mac mini Late 2012 Cowling Replacement: 5 단계, 이미지 3/3
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
    • Do not pry at the socket, or you may rip it from the logic board.
    • Remove the fan.
  6. Mac mini Late 2012 Cowling Replacement, Cowling: 6 단계, 이미지 1/1
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
  7. Mac mini Late 2012 Cowling Replacement: 7 단계, 이미지 1/1
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
503,848 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 17,687개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 38
전체 시간: 6,604
