소개
Use this guide to replace the hard drive cable in your hard drive only or Fusion Drive Mac mini Late 2014.
This guide was made with a Fusion Drive Mac mini. If your Mac mini only has a hard drive, skip the steps about the PCIe SSD and its connector.
필요한 것
The bottom cover is clipped onto three screw posts.
Pry near, but not right on the screw posts.
Remove the following TR6 screws from the antenna plate:
Three 4.1 mm screws
Three 1.9 mm screws
Remove the two 12 mm T6 screws from the fan.
Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
이 단계에 사용된 도구:Mac mini Logic Board Removal Tool$4.99
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
Remove the four (two on each side) 6.5 mm T8 screws securing the hard drive to the drive tray.
Lift up the ribbon cable and carefully peel away the black tape underneath. It secures the SATA cable connector to the PCB of the hard drive. Failing to remove the tape will almost surely cause the contacts soldered to the flex cable to rip from the connector housing, as the retention force of the contacts in the housing is quite low.
Pull the SATA cable connector straight out of the hard drive.
Carefully peel off the two black, square-shaped sticky pads (one visible in picture) from the corners of the hard drive, and stick them to your new hard drive in the same locations.
다른 27명이 해당 안내서를 완성하였습니다.
