주요 콘텐츠로 건너뛰기
Mac mini Late 2014 PCIe SSD Cable Replacement
필요한 것
  1. Mac mini Late 2014 PCIe SSD Cable Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 PCIe SSD Cable Replacement: 2 단계, 이미지 1/3 Mac mini Late 2014 PCIe SSD Cable Replacement: 2 단계, 이미지 2/3 Mac mini Late 2014 PCIe SSD Cable Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 PCIe SSD Cable Replacement: 3 단계, 이미지 1/2 Mac mini Late 2014 PCIe SSD Cable Replacement: 3 단계, 이미지 2/2
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 PCIe SSD Cable Replacement, Antenna Plate: 4 단계, 이미지 1/1
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 PCIe SSD Cable Replacement: 5 단계, 이미지 1/2 Mac mini Late 2014 PCIe SSD Cable Replacement: 5 단계, 이미지 2/2
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 PCIe SSD Cable Replacement: 6 단계, 이미지 1/1
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 PCIe SSD Cable Replacement: 7 단계, 이미지 1/2 Mac mini Late 2014 PCIe SSD Cable Replacement: 7 단계, 이미지 2/2
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 PCIe SSD Cable Replacement: 8 단계, 이미지 1/2 Mac mini Late 2014 PCIe SSD Cable Replacement: 8 단계, 이미지 2/2
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 PCIe SSD Cable Replacement: 9 단계, 이미지 1/1
    • Remove the antenna plate from the Mac mini.
  10. Mac mini Late 2014 PCIe SSD Cable Replacement, SSD: 10 단계, 이미지 1/1
    • Remove the 5 mm T5 screw securing the SSD.
  11. Mac mini Late 2014 PCIe SSD Cable Replacement: 11 단계, 이미지 1/3 Mac mini Late 2014 PCIe SSD Cable Replacement: 11 단계, 이미지 2/3 Mac mini Late 2014 PCIe SSD Cable Replacement: 11 단계, 이미지 3/3
    • Lift the free end of the SSD up slightly and pull it out of its socket.
  12. Mac mini Late 2014 PCIe SSD Cable Replacement: 12 단계, 이미지 1/3 Mac mini Late 2014 PCIe SSD Cable Replacement: 12 단계, 이미지 2/3 Mac mini Late 2014 PCIe SSD Cable Replacement: 12 단계, 이미지 3/3
    • Carefully lift the SSD out of the case without scratching or touching the gold contacts.
  13. Mac mini Late 2014 PCIe SSD Cable Replacement, PCIe SSD Cable: 13 단계, 이미지 1/1
    • Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
  14. Mac mini Late 2014 PCIe SSD Cable Replacement: 14 단계, 이미지 1/2 Mac mini Late 2014 PCIe SSD Cable Replacement: 14 단계, 이미지 2/2
    • Remove the PCIe SSD cable bracket.
  15. Mac mini Late 2014 PCIe SSD Cable Replacement: 15 단계, 이미지 1/2 Mac mini Late 2014 PCIe SSD Cable Replacement: 15 단계, 이미지 2/2
    • Use the flat end of a spudger to lift the PCIe SSD connector straight up off of its connector on the logic board.
    • Be careful not to pry up on the socket itself.
  16. Mac mini Late 2014 PCIe SSD Cable Replacement: 16 단계, 이미지 1/2 Mac mini Late 2014 PCIe SSD Cable Replacement: 16 단계, 이미지 2/2
    • Slip the flat end of a spudger under the SSD cable to lift it off the adhesive holding it to the Mac mini.
  17. Mac mini Late 2014 PCIe SSD Cable Replacement: 17 단계, 이미지 1/1
    • Remove the PCIe SSD cable from the Mac mini.
결론
다른 28명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
466,487 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
137 회원들
안내서 17,524개 작성하였습니다
댓글 8개
Where i can buy the PCIe SSD card?
melvin suarez - 답글
Where i can buy the PCIe SSD card, someone?
Claudio Vargas - 답글
I can supply these cables. Please reply to this thread.
Thomas Hall -
I found the ssd kit on eBay for $69ish. However, it doesn't include the ssd. Is it mPCI-e or is it an M.2 module?
Angelo - 답글
The SSD is neither, I believe. It is the same as the SSDs in the 2014 and up MacBook Pros. Pin format is 12+16
Daniel Abdulla -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 47
30일 전: 214
전체 시간: 58,156
