주요 콘텐츠로 건너뛰기
Mac mini Mid 2011 Bottom Cover Replacement
필요한 것
  1. Mac mini Mid 2011 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 1/2 Mac mini Mid 2011 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
  2. Mac mini Mid 2011 Bottom Cover Replacement: 2 단계, 이미지 1/1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
결승점
다른 17명이 해당 안내서를 완성하였습니다.
Walter Galan
695,321 평판
안내서 1,203개 작성하였습니다
댓글 2개
The base plate on my MM has no thumb dimples, no “lock dots”, and it won’t budge. I’ve tried everything short of prying it off—light touch, firm touch, thumbs, palm, nothing has worked. Any suggestions?
Jonathan Royce - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 42
전체 시간: 24,372
