소개
Use this guide to replace a noisy or burned-out fan.
필요한 것
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
거의 끝나갑니다!
결론
다른 78명이 해당 안내서를 완성하였습니다.
