주요 콘텐츠로 건너뛰기
MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement
필요한 것
  1. MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement, Lower Case: 1 단계, 이미지 1/1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement: 2 단계, 이미지 1/1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
결론
다른 18명이 해당 안내서를 완성하였습니다.
Walter Galan
695,729 평판
안내서 1,203개 작성하였습니다
댓글 한 개
Walter, please, change this guide's difficulty from moderate to easy :D
It's really that simple.
P.S. You've really saved me. I opened it by myself but then noticed that screws were different size. Oh, I always remember iFixit and opened it cuz I was sure that I'll find smth here. Many thanks!
Jizo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 57
전체 시간: 29,923
