주요 콘텐츠로 건너뛰기
MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement
필요한 것
  1. MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement, Lower Case: 1 단계, 이미지 1/1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement: 2 단계, 이미지 1/2 MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement: 2 단계, 이미지 2/2
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement, Right Fan: 3 단계, 이미지 1/3 MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement, Right Fan: 3 단계, 이미지 2/3 MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement, Right Fan: 3 단계, 이미지 3/3
    • Use a spudger to pry the fan connector straight up off the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  4. MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement: 4 단계, 이미지 1/1
    • Remove three T6 Torx screws securing the right fan to the logic board and upper case.
  5. MacBook Pro 15" Unibody Mid 2009 Right Fan Replacement: 5 단계, 이미지 1/1
    • Lift the right fan out of the upper case.
결론
다른 56명이 해당 안내서를 완성하였습니다.
Walter Galan
695,306 평판
안내서 1,203개 작성하였습니다
댓글 4개
Merci à iFixIt pour la qualité des pièces fournies et la rapidité à laquelle elles ont été expédiées.
Merci à Walter pour la clarté de son tuto, et aux traducteur pour la traduction !
Que du bonheur !
Fabrice CROMBEZ - 답글
Hello Walter, I have a mid 2009 macbook pro 15” and it has only one fan. I need to replace it. Which one should I buy?
bikkon yestal - 답글
thank you Team iFixit! this definitely is helping extend the life of my 10 year old (GASP!!!) MBP 15” A1286 !
Kahana - 답글
Same thing I said for the left fan:
Great guide, easy work to do! If I can do this, anyone can. If I can do this, someone who does not exist almost can. Not quite! But almost. I was happy to get that squalling and howling old fan out of my MacBook Pro, and thereby to end the squalling & howling I got from my family over the noise it made. Like the old one, the new fan works great, but it is new, and quiet, and I am thankful. Happy customer.
pstewart - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 19,875
