주요 콘텐츠로 건너뛰기
Nikon D80 Rear LCD Screen Replacement
필요한 것
  1. Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: 1 단계, 이미지 1/3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: 1 단계, 이미지 2/3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: 1 단계, 이미지 3/3
    • Using a Philips #00 screwdriver, remove the four 6.2mm from the left and right sides of the outer cover.
  2. Nikon D80 Rear LCD Screen Replacement: 2 단계, 이미지 1/3 Nikon D80 Rear LCD Screen Replacement: 2 단계, 이미지 2/3 Nikon D80 Rear LCD Screen Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable away from the main body of the camera using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Rear LCD Screen Replacement: 3 단계, 이미지 1/2 Nikon D80 Rear LCD Screen Replacement: 3 단계, 이미지 2/2
    • Using a Philips #00 screwdriver, remove the three 4.3 mm screws by rotating screwdriver to the left.
    • Use the Phillips #00 screwdriver to remove the two 3.4 mm screws.
  4. Nikon D80 Rear LCD Screen Replacement: 4 단계, 이미지 1/2 Nikon D80 Rear LCD Screen Replacement: 4 단계, 이미지 2/2
    • Using blunt tweezers, gently flip the small locking flap of the zero force insertion connector up for both connectors.
    • Use blunt tweezers to pull the left ribbon connector out of the zero insertion force connector.
    • Using the same tweezers, pull the right ribbon connector out of the zero insertion force connector.
  5. Nikon D80 Rear LCD Screen Replacement: 5 단계, 이미지 1/2 Nikon D80 Rear LCD Screen Replacement: 5 단계, 이미지 2/2
    • Slide out the LCD screen by pulling towards the right.
    • Remove the LCD screen.
    • The buttons beside the screen fall out easily. Remember where they were and put them back when finished with the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sara Martin
회원 가입일: 10/09/17
586 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G1, Leahy Fall 2017 USF Tampa, Team S1-G1, Leahy Fall 2017 회원
USFT-LEAHY-F17S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 41
전체 시간: 2,928
