주요 콘텐츠로 건너뛰기
Nokia Lumia 520 Audio Jack Replacement
필요한 것
  1. Nokia Lumia 520 Audio Jack Replacement, Battery: 1 단계, 이미지 1/2 Nokia Lumia 520 Audio Jack Replacement, Battery: 1 단계, 이미지 2/2
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Audio Jack Replacement: 2 단계, 이미지 1/2 Nokia Lumia 520 Audio Jack Replacement: 2 단계, 이미지 2/2
    • Lift the spudger gently to open the back cover of the phone.
  3. Nokia Lumia 520 Audio Jack Replacement: 3 단계, 이미지 1/2 Nokia Lumia 520 Audio Jack Replacement: 3 단계, 이미지 2/2
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
  4. Nokia Lumia 520 Audio Jack Replacement, Audio Jack: 4 단계, 이미지 1/3 Nokia Lumia 520 Audio Jack Replacement, Audio Jack: 4 단계, 이미지 2/3 Nokia Lumia 520 Audio Jack Replacement, Audio Jack: 4 단계, 이미지 3/3
    • Unscrew the 8 screws with a Torx screw driver (T4) and make sure you know what screws went where because they are different.
  5. Nokia Lumia 520 Audio Jack Replacement: 5 단계, 이미지 1/2 Nokia Lumia 520 Audio Jack Replacement: 5 단계, 이미지 2/2
    • Use your plastic spudger to remove the clips on the plastic casing over the motherboard. Note there are 10 clips holding the casing on(3 on the sides, 2 on the top and bottom).
  6. Nokia Lumia 520 Audio Jack Replacement: 6 단계, 이미지 1/2 Nokia Lumia 520 Audio Jack Replacement: 6 단계, 이미지 2/2
    • Carefully unclip the digitizer touch screen cable and the display screen cable using the spudger.
  7. Nokia Lumia 520 Audio Jack Replacement: 7 단계, 이미지 1/2 Nokia Lumia 520 Audio Jack Replacement: 7 단계, 이미지 2/2
    • Gently remove the motherboard.
  8. Nokia Lumia 520 Audio Jack Replacement: 8 단계, 이미지 1/2 Nokia Lumia 520 Audio Jack Replacement: 8 단계, 이미지 2/2
    • Use the plastic spudger and gently remove the audio jack and the flex connector to the audio jack away from the case.
    • You will feel some pressure since the audio jack is held in place with two sided tape.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Tyler Chellis
회원 가입일: 11/03/15
249 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 UMass Dartmouth, Team 1-5, Bhusal Fall 2015 회원
UMASSD-BHUSAL-F15S1G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 2,665
