소개
Use this guide to replace the external metal silent switch.
필요한 것
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm Pentalobe P2 screws next to the dock connector.
Remove the following screws securing the battery connector to the logic board:
One 1.7 mm Phillips screw
One 1.5 mm Phillips screw
Insert the edge of a plastic opening tool between the battery and the outer case near the bottom of the iPhone.
Run the plastic opening tool along the right edge of the battery and pry up at several points to completely separate it from the adhesive securing it to the outer case.
Wait about one minute for the alcohol solution to weaken the adhesive.
Use the flat end of a plastic opening tool to gently lift the battery.
Remove the following screws securing the dock connector cable cover to the logic board:
One 1.2 mm Phillips screw
Remove the metal dock connector cable cover.
Use a SIM eject tool or a paperclip to eject the SIM and its tray.
Remove the SIM and its tray.
Remove the five cables near the top of the logic board in the following order:
Headphone jack/volume button cable
Front facing camera cable
Digitizer cable
Display data cable
Power button cable (located underneath the headphone jack/volume button cable as shown in the second picture.)
Use the edge of a plastic opening tool to carefully pry the metal front facing camera retainer away from the case of your iPhone.
Remove the front facing camera retainer.
Use a plastic opening tool to start to pry the headphone jack out of its recess in the rear case.
Then use the opening tool to gently peel the microphone up from the adhesive securing it to the top of the rear case.
Remove the headphone jack assembly from the rear case, being careful not to tear the microphone flex cable.
다른 64명이 해당 안내서를 완성하였습니다.
댓글 4개
My iPhone 4s when on silent keeps jumping to loud by itself. Fixed it by wedging bit of folded cardboard inbetween battery and the ribbon wire which goes to switch
Same problem. Explain briefly. First timer.
Great guide. Easy to follow the step by step instructions with visual guide. But, what would make it slightly better for total beginners like me would be to provide a guide on how to put it back together again. Lol. Also if you could show how to exactly fit the new flex with the silent button as im having trouble keeping it in place/position.
Hi. I just made all steps to replace the conexion of the volume up/down that were damaged by water, I fixed it BUT: now the headphone may be making a contact that says to the iPhone that there's a jack inserted, then the speakers doesn't make any sound. All other thing looks fine, including the mic. Only the SIM card died, but it was very used and I will ask for a new one).
Any idea about what happens to the speaker or the headphone conexion?
I'm very tired after this difficult operation then I will back later. Thank you.
Guillermo, from Madrid, Spain.
