주요 콘텐츠로 건너뛰기
How to Embed a Guide or Teardown
  1. How to Embed a Guide or Teardown, View teardown or guide: 1 단계, 이미지 1/1
    • Navigate to the teardown or guide page that you would like to embed.
  2. How to Embed a Guide or Teardown, Select language (optional): 2 단계, 이미지 1/3 How to Embed a Guide or Teardown, Select language (optional): 2 단계, 이미지 2/3 How to Embed a Guide or Teardown, Select language (optional): 2 단계, 이미지 3/3
    • If you wish to embed the guide or teardown in a different language than the one currently selected:
    • Click on the language icon in the upper right of the header bar.
    • In the pop-up window, click to select the desired language.
    • The site will load the page in the selected language.
  3. How to Embed a Guide or Teardown, Create embed code: 3 단계, 이미지 1/2 How to Embed a Guide or Teardown, Create embed code: 3 단계, 이미지 2/2
    • Click the "Options" button on the upper-righthand corner of the page.
    • Select "Embed This Guide" from the dropdown menu.
  4. How to Embed a Guide or Teardown, Copy embed code: 4 단계, 이미지 1/2 How to Embed a Guide or Teardown, Copy embed code: 4 단계, 이미지 2/2
    • A pop-up window will appear with an HTML embed code and a preview of your embedded guide.
    • Select the size you wish the embedded guide to be.
    • Copy the auto-generated HTML code.
  5. How to Embed a Guide or Teardown, Embed guide on your site: 5 단계, 이미지 1/2 How to Embed a Guide or Teardown, Embed guide on your site: 5 단계, 이미지 2/2
    • Paste your HTML code into the site's text box.
    • Enjoy your embedded guide!
결승점
다른 11명이 해당 안내서를 완성하였습니다.
Julia
회원 가입일: 02/09/12
2,015 평판
안내서 1개 작성함
댓글 3개
Fix blinking screen on startup
Richard Woolwine - 답글
Is there an API to access contents?
Luca Orlandi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 55
전체 시간: 3,933
