주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
battery dies at 50%
I purchased a new battery from you guys and installed it. When I installed it it was dead. Pluged it in and it took 30min for it to turn on, Let it charge till it was completely charged,. Now when it gets to 50% it shuts off saying battery dead. Did I get a bad battery
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
ag ana dndn ansnf
댓글 달기
답변 4개
선택된 답변
You could have gotten a bad battery. This is one symptom.
Contact sales@ifixit.com and tell them about your problem.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Did you put the battery grounding clip back on under the battery clip? Because if you don't have it on, you may have a issue like this.
Exact battery ground clip installation, iPhone 4s?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
bad battery certainly
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
New batteries have never been charged so you set the life of that battery with the first 3-4 complete charge/discharge cycles that every seller recommend to do. You should let the battery charge with the phone off for 10-12 hours for these cycles then you can use it as you want. It makes a big difference, that's why I think that the battery you have is acting like this. If after making it charge and discharge like this it keeps working bad you probably have a bad battery.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
tammy barlock 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 330
