주요 콘텐츠로 건너뛰기
Game Boy Advance Screen Replacement
필요한 것
동영상 개요
  1. Game Boy Advance Screen Replacement, Game Boy Advance Teardown: 1 단계, 이미지 1/3 Game Boy Advance Screen Replacement, Game Boy Advance Teardown: 1 단계, 이미지 2/3 Game Boy Advance Screen Replacement, Game Boy Advance Teardown: 1 단계, 이미지 3/3
    • Remove the back battery cover by pinching down on the tab and pulling outward.
  2. Game Boy Advance Screen Replacement: 2 단계, 이미지 1/1
    • Remove the six back panel screws using a Y1 screw driver.
  3. Game Boy Advance Screen Replacement: 3 단계, 이미지 1/1
    • Remove bottom back panel screw with a Phillips #1 screw driver.
  4. Game Boy Advance Screen Replacement: 4 단계, 이미지 1/1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Beware of right and left triggers, the right and left panels, and the power switch falling off as the back panel is removed.
  5. Game Boy Advance Screen Replacement: 5 단계, 이미지 1/2 Game Boy Advance Screen Replacement: 5 단계, 이미지 2/2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels.
    • For finicky or jammed triggers only. Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  6. Game Boy Advance Screen Replacement: 6 단계, 이미지 1/2 Game Boy Advance Screen Replacement: 6 단계, 이미지 2/2
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  7. Game Boy Advance Screen Replacement: 7 단계, 이미지 1/1
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
    • The last screw on the right is not included on some Game Boy Advance systems.
  8. Game Boy Advance Screen Replacement: 8 단계, 이미지 1/2 Game Boy Advance Screen Replacement: 8 단계, 이미지 2/2
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Beware not to damage the top ribbon by pulling up gently.
  9. Game Boy Advance Screen Replacement: 9 단계, 이미지 1/3 Game Boy Advance Screen Replacement: 9 단계, 이미지 2/3 Game Boy Advance Screen Replacement: 9 단계, 이미지 3/3
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  10. Game Boy Advance Screen Replacement: 10 단계, 이미지 1/3 Game Boy Advance Screen Replacement: 10 단계, 이미지 2/3 Game Boy Advance Screen Replacement: 10 단계, 이미지 3/3
    • Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB).
    • Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
  11. Game Boy Advance Screen Replacement: 11 단계, 이미지 1/3 Game Boy Advance Screen Replacement: 11 단계, 이미지 2/3 Game Boy Advance Screen Replacement: 11 단계, 이미지 3/3
    • Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
    • The screen and the front panel is connected by a black tape that could rip if not removed carefully.
    • You can use an iOpener or a hair dryer on the other side of the front panel in order to soften the black tape.
  12. Game Boy Advance Screen Replacement: 12 단계, 이미지 1/1
    • Use the tweezers to remove the black tape if needed.
결승점
다른 18명이 해당 안내서를 완성하였습니다.
Adam
회원 가입일: 01/20/10
815 평판
안내서 5개 작성하였습니다
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010 회원
CPSU-MANESS-W10S16G29
5 회원들
안내서 61개 작성하였습니다
댓글 6개
Doesn't say where you can get new screen !!!!??
andrew Davies - 답글
Doesn't say where to get screen from !!!??
andrew Davies - 답글
Do this with the Game Boy Advance SP please!
Santi12008 - 답글
It does not say where you can get a new screen
criscaanca - 답글
DONT DO THIS LIKE THAT!!!. The area of the screen in the space beside the D-pad is the only area where the LCD glass is completely exposed. It’s Literaly the WORST place to apply pressure, 99% chances for the LCD to break. There is a notch on the top right corner and another under the ribbon cable. Making your way from the top right to the left is far more safe.
Flyingmcintosh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 135
30일 전: 477
전체 시간: 38,064
