주요 콘텐츠로 건너뛰기
Nintendo Game Boy Advance SP Battery Replacement
필요한 것
  1. Nintendo Game Boy Advance SP Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Battery Replacement: 2 단계, 이미지 1/1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Battery Replacement: 3 단계, 이미지 1/1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
결론
For reassembly, follow the instructions in reverse order.
다른 30명이 해당 안내서를 완성하였습니다.
Rocco Lattanzio
회원 가입일: 01/11/13
1,006 평판
안내서 2개 작성하였습니다
Cal Poly, Team 17-22, Forte Winter 2013 Cal Poly, Team 17-22, Forte Winter 2013 회원
CPSU-FORTE-W13S17G22
4 회원들
안내서 39개 작성하였습니다
댓글 2개
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
Santi12008 - 답글
Thanks for yout guideline. I settle in 5 minutes.
aam9999 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 17
7일 전: 202
30일 전: 1,038
전체 시간: 64,768
