주요 콘텐츠로 건너뛰기
Patch a Patagonia Down Jacket with Repair Tape
필요한 것
  1. Patch a Patagonia Down Jacket with Repair Tape, Patch a Patagonia Down Jacket with Repair Tape: 1 단계, 이미지 1/1
    • Inspect the damage. Clip any dangling threads, fabric, or feathers using small scissors. .
    • Do not pull feathers out with your finger. Pulling feathers encourages more feathers to come out the hole and makes the problem worse.
    • Clean the fabric area that you are repairing with Isopropyl alcohol prior to applying the patch. This will remove dirt and oil allowing the adhesive to bond well to the fabric. Allow fabric to dry for a short period before adhering the patch
  2. Patch a Patagonia Down Jacket with Repair Tape: 3 단계, 이미지 1/3 Patch a Patagonia Down Jacket with Repair Tape: 3 단계, 이미지 2/3 Patch a Patagonia Down Jacket with Repair Tape: 3 단계, 이미지 3/3
    • Grab your repair tape.
    • Flip the repair tape to the back side.
    • Using a permanent marker, draw an oval slightly larger than the hole.
    • If you have a wide hole, you can use a rectangle, but be sure to round the edges. Rounding the edges prevents the corners from getting caught and peeling up.
  3. Patch a Patagonia Down Jacket with Repair Tape: 4 단계, 이미지 1/2 Patch a Patagonia Down Jacket with Repair Tape: 4 단계, 이미지 2/2
    • Cut out your shape using scissors.
  4. Patch a Patagonia Down Jacket with Repair Tape: 5 단계, 이미지 1/2 Patch a Patagonia Down Jacket with Repair Tape: 5 단계, 이미지 2/2
    • Lay the shape over the hole to ensure that the patch is large enough. You want the patch to cover the hole or tear and extend past damaged area onto the fabric on all sides with at least an 1/4" of overlap.
  5. Patch a Patagonia Down Jacket with Repair Tape: 6 단계, 이미지 1/3 Patch a Patagonia Down Jacket with Repair Tape: 6 단계, 이미지 2/3 Patch a Patagonia Down Jacket with Repair Tape: 6 단계, 이미지 3/3
    • Using your fingernail, or a pin, peel the backing off the repair tape, so that you only have the clear sticky layer.
    • Be sure not to touch the sticky side, as this will gum up the tape and it will not stick well.
  6. Patch a Patagonia Down Jacket with Repair Tape: 7 단계, 이미지 1/3 Patch a Patagonia Down Jacket with Repair Tape: 7 단계, 이미지 2/3 Patch a Patagonia Down Jacket with Repair Tape: 7 단계, 이미지 3/3
    • Lay the tape over the hole and press the tape down with your finger.
  7. Patch a Patagonia Down Jacket with Repair Tape: 8 단계, 이미지 1/2 Patch a Patagonia Down Jacket with Repair Tape: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Use a spudger, hard plastic card or the edge of your thumb to smooth out patch and work out any air bubbles underneath. Continue to smooth out patch by applying downward pressure onto patch, pushing out towards the edges in all directions.
    • Using your warm hand continue to apply pressure until properly adhered.
    • Allow patch to set for at least 24hrs before next wash.
결승점
다른 25명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
89,014 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 10개
I have now put four or five tenacious tape patches on my son's down sweater (9 year old are tough in VT). But now it is very dirty. Can I wash it like I would if it didn't have the tenacious tape - or do i need to do something different?
Hylah - 답글
Hi Hylah, Yes you can wash your jacket and if the patches are starting to peel a little after 7 years you have some options. 1) Contact Patagonia Burlington Store and ask for some more patches, each store has a variety of patches, zipper sliders, Zipper pulls, snaps, buttons to help with easy repairs. 2) Send it to us for Repair, you could take it to the store or start the process on-line . https://www.patagonia.com/returns.html
Holes are not warranty but due to wear and tear, we will repair it for you no problem. Our goal is to keep product in use as long as possible. After they have reached there end of life use, we can recycle it for you and then you can invest in another long lasting durable product. Please check out this link for additional questions. https://help.patagonia.com/s/article/Rep...
Marty Chapman -
its water proof so i guess it can be washed
sheilaym1 - 답글
Hi Sheilaym 1, Everything we make can be washed, Cold water Low tumble dry. It's good to wash your shells every once in a while to remove dirt and oils.
Marty Chapman -
I've found super glue works pretty well and doesn't show the down.
Patrick Marcott - 답글
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 153
30일 전: 805
전체 시간: 370,972
