주요 콘텐츠로 건너뛰기
Sony KDF-E60A20 Lamp Replacement
필요한 것
  1. Sony KDF-E60A20 Lamp Replacement, Lamp: 1 단계, 이미지 1/3 Sony KDF-E60A20 Lamp Replacement, Lamp: 1 단계, 이미지 2/3 Sony KDF-E60A20 Lamp Replacement, Lamp: 1 단계, 이미지 3/3
    • Remove the two thumb screws.
  2. Sony KDF-E60A20 Lamp Replacement: 2 단계, 이미지 1/3 Sony KDF-E60A20 Lamp Replacement: 2 단계, 이미지 2/3 Sony KDF-E60A20 Lamp Replacement: 2 단계, 이미지 3/3
    • With both thumb screws removed, the front bezel can now be easily pulled off. It is only held in place by three magnets.
    • With the bezel out of the way, there will be a small cover held in place by a crossbar and a thumb screw. Loosen the thumb screw and fold the bar out of the way.
    • The back of the lamp housing is now visible.
  3. Sony KDF-E60A20 Lamp Replacement: 3 단계, 이미지 1/3 Sony KDF-E60A20 Lamp Replacement: 3 단계, 이미지 2/3 Sony KDF-E60A20 Lamp Replacement: 3 단계, 이미지 3/3
    • Loosen the 3mm Allen bolt. It will not come out of the lamp housing, but will loosen it to remove the lamp housing from the TV.
    • With the Allen bolt loose, pull the lamp houing slightly back and down,
    • this will remove the lamp in its housing.
  4. Sony KDF-E60A20 Lamp Replacement: 4 단계, 이미지 1/3 Sony KDF-E60A20 Lamp Replacement: 4 단계, 이미지 2/3 Sony KDF-E60A20 Lamp Replacement: 4 단계, 이미지 3/3
    • Here is the old lamp and housing.
    • For the replacement, a complete lamp and housing was chosen. The lamp is individually available. There was not a big difference in cost, to justify the additional steps of replacing the lamp housing.
    • Install the new lamp and housing
  5. Sony KDF-E60A20 Lamp Replacement: 5 단계, 이미지 1/1
    • Result of this $32 repair is a bright fully functioning TV
결론
다른 13명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
781,527 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
32 회원들
안내서 531개 작성하였습니다
댓글 17개
Where did you purchase this bulb for $32?
Wendy Watson - 답글
Mine worked 4 3 hours then stayed off.
Love machine Guaranteed -
I ordered a replacement housing with new bulb in it and with shipping it was 35. Ordered it thru Sears online and they sent it out next day air. It took five min to swap out
Joker - 답글
Thanks a lot. You saved me money
Alexander Ritchie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 19
전체 시간: 24,914
