주요 콘텐츠로 건너뛰기
Xbox One Wireless Controller Thumbstick Replacement
필요한 것
  1. Xbox One Wireless Controller Thumbstick Replacement, Battery Pack: 1 단계, 이미지 1/1
    • Remove the battery pack cover.
    • Remove batteries.
  2. Xbox One Wireless Controller Thumbstick Replacement, Side Handles: 2 단계, 이미지 1/2 Xbox One Wireless Controller Thumbstick Replacement, Side Handles: 2 단계, 이미지 2/2
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
  3. Xbox One Wireless Controller Thumbstick Replacement, Screws: 3 단계, 이미지 1/2 Xbox One Wireless Controller Thumbstick Replacement, Screws: 3 단계, 이미지 2/2
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
  4. Xbox One Wireless Controller Thumbstick Replacement, Backplate: 4 단계, 이미지 1/1
    • Remove the backplate.
  5. Xbox One Wireless Controller Thumbstick Replacement, Faceplate: 5 단계, 이미지 1/1
    • Remove the faceplate.
  6. Xbox One Wireless Controller Thumbstick Replacement, Thumbstick: 6 단계, 이미지 1/2 Xbox One Wireless Controller Thumbstick Replacement, Thumbstick: 6 단계, 이미지 2/2
    • Remove thumbsticks by pulling them up off their poles.
결론
다른 188명이 해당 안내서를 완성하였습니다.
Garrett George
회원 가입일: 01/22/15
6,154 평판
안내서 3개 작성하였습니다
Cal Poly, Team 20-15, Maness Winter 2015 Cal Poly, Team 20-15, Maness Winter 2015 회원
CPSU-MANESS-W15S20G15
5 회원들
안내서 50개 작성하였습니다
댓글 30개
Is there any advice for a controller that has had this repair, but continues to drift? I have done this repair successfully many times, and now i have a controller that (with 2 different replacement parts) continues to drift.
Is there a reset or config I can do?
Jim - 답글
Drift issues are a different problem you would need to solder a new joystick box to fix that this is for loose or damaged thumb sticks
myhero667 -
I used a cotton ball on my Xbox one Elite to fix drifting issues.
ajcroyle -
Does anyone know the correct SKU for the joystick box for the Model 1537 in particular? And any link to purchase it. Thanks
ZuYao -
Can i apply 2 thumbsticks off the xbox 360 controller when i removed them?
Merlijn Fransen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 53
7일 전: 356
30일 전: 1,629
전체 시간: 367,212
