<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;4-Stroke Small Gas Engine&quot;]]></title>
<link>https://ko.ifixit.com/Answers/Device/4-Stroke_Small_Gas_Engine?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;4-Stroke Small Gas Engine&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 06 Sep 2026 10:06:51 -0700</pubDate>
<item>
<title><![CDATA[4-Stroke Small Gas Engine: Why does my lawnmower start and die even with a new carburetor?]]></title>
<description><![CDATA[<p>We have a Yard Machine push lawnmower with a  09p702-0004-F1 Briggs and Straton engine on it.  We got the lawn mowed once this spring with it, but since then it has refused to run. It turns over, starts up and then dies.</p>
<p>After researching on the internet, we cleaned the carb with some carb cleaner. If you spray carb cleaner in it started and ran as you kept on spraying carb cleaner in.  We took apart, then reassembled the carb. That didn’t help.  We checked the fuel line - fuel flows freely out of it. Drained all of the fuel out, put in new fuel. Nope. Tried it with the gas tank cap off. Nada. Constantly pumping the primer once it starts doesn’t seem to help at all.  Cleaned the spark plug.</p>
<p>We then ordered a replacement carburetor. Installed that today - still no go. It continues to turn over, start and then die immediate.</p>
<p>Where to go from here? The lawn grows longer by the day - we resorted to using the string trimmer on it last week . . .</p>
<p>⟐ Answered 5월 09, 2020 at 10:51 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/633431/Why+does+my+lawnmower+start+and+die+even+with+a+new+carburetor</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/633431</guid>
<pubDate>Sat, 09 May 2020 10:51:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[4-Stroke Small Gas Engine: Briggs and Stratton 14.5 OHV 500cc Valve Settings]]></title>
<description><![CDATA[<p>Valve cover has the following stamped on it Model Type Code 31A507 0871 05 120322ZD.  Reqire Exhaust and Intake valve setting for this particular model.  Thank you.</p>
<p>⟐ Commented 5월 12, 2019 at 22:52 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/498481/Briggs+and+Stratton+14.5+OHV+500cc+Valve+Settings</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/498481</guid>
<pubDate>Sun, 12 May 2019 22:52:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[4-Stroke Small Gas Engine: mower clicks several times before starting]]></title>
<description><![CDATA[<p>Simplicty consumer zero turn with 20hp Vangaurd. I replaced engine with identical engine from parts machine. starter has always clicked at the starter several times before cranking and starting. so I replaced starter with one from the blown engine. It does the same thing except now it is the solenoid that is clicking.</p>
<p>⟐ Commented 4월 17, 2022 at 9:51 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/729188/mower+clicks+several+times+before+starting</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/729188</guid>
<pubDate>Sun, 17 Apr 2022 09:51:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda General Purpose Engine GX200UT2: engine wont turn on]]></title>
<description><![CDATA[<p>whenever i try to turn on engine it sputters a little but never starts</p>
<p>⟐ Answer edited 7월 28, 2025 at 16:14 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/908863/engine+wont+turn+on</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/908863</guid>
<pubDate>Mon, 28 Jul 2025 16:14:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda 4Stroke Engine GX360: Question about pull start]]></title>
<description><![CDATA[<p>I have an atv and I just put a new pull start recoil on it and when I pull start the atv it is a short pull string and it is trying to start but  not very long is it because the pull string is too short do I need a new pull string</p>
<p>⟐ Answered 2월 04, 2021 at 7:28 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/670716/Question+about+pull+start</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/670716</guid>
<pubDate>Thu, 04 Feb 2021 07:28:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[4-Stroke Small Gas Engine: Starts, surges and dies]]></title>
<description><![CDATA[<p>Ok. I have a 5hp Briggs &amp; Stratton on my MTD rototiller.  I've changed the carb gasket, see picture. I've cleaned out the passages. I've used sea foam in the fuel, it's got fairly new gas. I cleaned and checked the gap in the spark plug and it's good. I can still see through the air filter.</p>
<p>But I can start it and it'll run for a few minutes then die. After the sea foam trick if I babied it I was able to do a little bit of rototilling, but then it died and wouldn't restart no matter where I positioned the choke lever.</p>
<p>What else could it be?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/XlGYbS1D4VeqqqVx.standard" width="110" height="225" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/XlGYbS1D4VeqqqVx.huge&quot;, '', 'width=584,height=1200')" /></div>
<p>⟐ Answered 11월 21, 2020 at 14:09 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/637533/Starts,+surges+and+dies</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/637533</guid>
<pubDate>Sat, 21 Nov 2020 14:09:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[4-Stroke Small Gas Engine: Mower stalls when I engage blades.]]></title>
<description><![CDATA[<p>Hi.  I have a John Deere zero turn mower. It runs great and cuts just fine.  However, I just installed the power flow bagging system and now the mower stalls when I attempt to engage the blades. Initially, when I first installed the power flow unit, which is belt driven, it worked but the mower struggled to get the power flow going but it eventually did. Now, just a few days later, the mower can’t get the power flow going. It doesn’t sound like a safety switch issue as the engine doesn’t just cut off, rather, it struggles and it sounds like it wants to go but the engine stalls … any help would be much appreciated!</p>
<p>⟐ Commented 11월 21, 2020 at 13:54 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/531151/Mower+stalls+when+I+engage+blades.</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/531151</guid>
<pubDate>Sat, 21 Nov 2020 13:54:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[4-Stroke Small Gas Engine: Replacing Carburetor Needle and Seat]]></title>
<description><![CDATA[<p>Briggs and Stratton 280000 series single cylinder engine is continuously flooding and needs the fuel bowl inlet “Needle and Seat” valve either replaced or adjusted. I have dismantled the unit but the Seat seems to be pressed in to the carburetor body. The design of the float seems to prevent any for of adjustment of the fuel level in the bowl.’</p>
<p>Hoping you can assist</p>
<p>⟐ Answer accepted 4월 09, 2020 at 16:28 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/626491/Replacing+Carburetor+Needle+and+Seat</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/626491</guid>
<pubDate>Thu, 09 Apr 2020 16:28:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[4-Stroke Small Gas Engine: Is my lawnmower about to blow up?]]></title>
<description><![CDATA[<p>First stage - lawmower started cutting out for no reason - I looked at solutions, cleaned the carburettor (with carb cleaner) and it ran slowly and unevenly eventually cutting out.</p>
<p>Second stage - I gave the carb a second more thorough clean with carb cleaner and WD40.</p>
<p>This time the engine started faster and louder than I can ever remember it being (I’ve had it some years so it might have been gently reducing speed in that time). After 3 minutes there was smoke coming from it and I lost my courage and stopped using it. Admittedly there is a chance the smoke was just old oil and petrol on the outside of the mower during the clean but before I use it again I’d like to know if I might have done anything to cause the mower to run too hot.</p>
<p>The Lawnmower is a Mccullough Vantage 55; the engine a Tecsumeh</p>
<p>Thoughts most welcome.</p>
<p>⟐ Answered 3월 18, 2019 at 12:49 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/523682/Is+my+lawnmower+about+to+blow+up</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/523682</guid>
<pubDate>Mon, 18 Mar 2019 12:49:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda General Purpose Motor GX160UT2  202002: It turn on. It will rev high]]></title>
<description><![CDATA[<p>I have adjusted the carburetor and governor. It seems to still rev high.</p>
<p>⟐ Answered 12월 23, 2025 at 16:50 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/727815/It+turn+on.+It+will+rev+high</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/727815</guid>
<pubDate>Tue, 23 Dec 2025 16:50:55 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda General Purpose Engine GX200UT2: Engine Stops running after 5 minutes, have to restart works again]]></title>
<description><![CDATA[<p>Engine Stops running after 5 minutes have to restart it works again for 5 minutes and stops again</p>
<p>⟐ Answered 7월 12, 2023 at 7:16 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/801158/Engine+Stops+running+after+5+minutes,+have+to+restart+works+again</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/801158</guid>
<pubDate>Wed, 12 Jul 2023 07:16:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda General Purpose Engine GX35: Swap with the GX25]]></title>
<description><![CDATA[<p>Will the GX35 mount to my Mantis tiller that has a GX25</p>
<p>⟐ Answered 7월 11, 2023 at 6:27 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/800751/Swap+with+the+GX25</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/800751</guid>
<pubDate>Tue, 11 Jul 2023 06:27:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda General Purpose Engine GX200UT2: Dies two minutes into the job]]></title>
<description><![CDATA[<p>I have replaced the fuel, the carburetor, checked the spark plugs, used starting fluid, cleaned the filter, checked the cap to the gas can.</p>
<p>It will run about two minutes and then die. It has gas flow and I have added a new fuel filter too.</p>
<p>⟐ Answered 5월 20, 2023 at 8:54 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/793182/Dies+two+minutes+into+the+job</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/793182</guid>
<pubDate>Sat, 20 May 2023 08:54:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda General Purpose Motor GX160UT2  202002: Pull cord mot starting]]></title>
<description><![CDATA[<p>Pull cord will not pull. Flywheel works perfectly, when i pull the cord, and then align it back , it does not retract. The flywheel rotor has limited movement</p>
<p>⟐ Answered 4월 05, 2023 at 20:31 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/701969/Pull+cord+mot+starting</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/701969</guid>
<pubDate>Wed, 05 Apr 2023 20:31:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[4-Stroke Small Gas Engine: spark plug sooty up]]></title>
<description><![CDATA[<p>i have a tecumseh wood chipper and the spark plug keeps getting sooted up and as hard time to start ? it not a Honda i at to choose that because it had no other to choose from ?</p>
<p>⟐ Edited 9월 18, 2022 at 6:36 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/747482/spark+plug+sooty+up</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/747482</guid>
<pubDate>Sun, 18 Sep 2022 06:36:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda 4Stroke Engine GX360: 1994 Polaris 400l recoil question(not correct motor mine not here)]]></title>
<description><![CDATA[<p>When I pull start my atv it makes a puffing noise then stops but the puffing noise is very quick can anyone tell me what is wrong let me know if you want a video of it doing the noise I can get you one.</p>
<p>⟐ Answered 12월 15, 2020 at 2:38 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/669167/1994+Polaris+400l+recoil+question(not+correct+motor+mine+not+here)</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/669167</guid>
<pubDate>Tue, 15 Dec 2020 02:38:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[4-Stroke Small Gas Engine: push rods to valves fall out. model #204412]]></title>
<description><![CDATA[<p>no gunk or buildup  on guides or valve stems. am scratching  my head.</p>
<p>⟐ Commented 8월 03, 2020 at 17:47 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/555969/push+rods+to+valves+fall+out.+model+%23204412</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/555969</guid>
<pubDate>Mon, 03 Aug 2020 17:47:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[4-Stroke Small Gas Engine: My Craftsman ys 4500 20 hp cranks but wont start even with start fluid]]></title>
<description><![CDATA[<p>I accidentally ran over a chunk of wood and the mower shut down so I figured I sheared the flywheel key and replaced it and the spark plug with no luck I also sprayed starting fluid into the air filter after taking the filter out and nothing happened it just cranks over very fast but won’t start PLEASE HELP !!</p>
<p>⟐ Answered 6월 15, 2019 at 12:37 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/572348/My+Craftsman+ys+4500+20+hp+cranks+but+wont+start+even+with+start+fluid</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/572348</guid>
<pubDate>Sat, 15 Jun 2019 12:37:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[4-Stroke Small Gas Engine: Throttle linkage for a Briggs & Stratton 42a707 engine]]></title>
<description><![CDATA[<p>Does anyone have a good picture of the throttle linkage for a Briggs &amp; Stratton 42a707</p>
<p>2238 e1 engine</p>
<p>⟐ Commented 6월 10, 2018 at 9:20 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/492145/Throttle+linkage+for+a+Briggs+&amp;+Stratton+42a707+engine</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/492145</guid>
<pubDate>Sun, 10 Jun 2018 09:20:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[4-Stroke Small Gas Engine: Jiang Dang C290 291cc engine]]></title>
<description><![CDATA[<p>I am looking for replacement parts for a Jiang Dang C290 291cc engine specifically the carberator and associated parts. The Carb is labeled  Huayi C290.9.1   Thanks for any help!</p>
<p>⟐ Commented 10월 21, 2024 at 15:57 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/874337/Jiang+Dang+C290+291cc+engine</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/874337</guid>
<pubDate>Mon, 21 Oct 2024 15:57:39 -0700</pubDate>
</item>
</channel>
</rss>
