<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Blood Pressure Monitor&quot;]]></title>
<link>https://ko.ifixit.com/Answers/Device/Blood_Pressure_Monitor/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Blood Pressure Monitor&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Wed, 09 Sep 2026 21:18:45 -0700</pubDate>
<item>
<title><![CDATA[Riester Blood Pressure Monitor: Can I replace my cord after it's broken]]></title>
<description><![CDATA[<p>Cord got broken</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/925107/Can+I+replace+my+cord+after+it&#039;s+broken</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/925107</guid>
<pubDate>Thu, 06 Nov 2025 07:15:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Blood Pressure Monitor: Blood pressure monitor does not turn on]]></title>
<description><![CDATA[<p>Blood pressure monitor does not turn on</p>
<p>⟐ Edited 5월 10, 2025 at 23:52 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/899595/Blood+pressure+monitor+does+not+turn+on</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/899595</guid>
<pubDate>Sat, 10 May 2025 23:52:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Blood Pressure Monitor: Digital blood pressure machine not working]]></title>
<description><![CDATA[<p>My BP machine isn't ON when I put new batteries inside and switch it ON. What is the problem and how can I fix it</p>
<p>⟐ Answered 5월 10, 2025 at 16:15 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/863481/Digital+blood+pressure+machine+not+working</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/863481</guid>
<pubDate>Sat, 10 May 2025 16:15:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[SunTech Oscar 2: SunTech Oscar 2 RTC Battery Replacement]]></title>
<description><![CDATA[<p>I replaced the Real Time Clock battery on a SunTech Oscar 2 M250 Monitor and when I turned the device on the &quot;rtc&quot; warning appears. The monitor appears locked and the blood pressure readings programming does not run. When I remove the main batteries, the programmed time is lost and the &quot;rtc&quot; warning appears again. Does anyone know the procedure to resolve this issue? Thanks.</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/887320/SunTech+Oscar+2+RTC+Battery+Replacement</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/887320</guid>
<pubDate>Sun, 09 Feb 2025 19:16:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Blood Pressure Monitor: generic digital blood pressure monitor is not reading pressure]]></title>
<description><![CDATA[<p>Power is on, all LEDs are working but not registering pressure and no determination, pump is working...bp monitor is an upper arm bp monitor.</p>
<p>⟐ Edited by author 1월 09, 2025 at 18:18 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/880873/generic+digital+blood+pressure+monitor+is+not+reading+pressure</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/880873</guid>
<pubDate>Thu, 09 Jan 2025 18:18:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Blood Pressure Monitor: se puede reparar monitor digital de muñeca]]></title>
<description><![CDATA[<p>The problem with my digital wrist monitor is that it doesn't exert enough pressure on the bracelet and immediately indicates error U which is &quot;insufficient pressure&quot;. I already disassembled it and I did not find fault at least in the compressor that starts and works and I also tested the air chamber is not broken, I do not know what it is,  another element connected to the hose-manifold that receives compressed air and takes it to the chamber and the electronic card.</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/875133/se+puede+reparar+monitor+digital+de+mu%C3%B1eca</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/875133</guid>
<pubDate>Sun, 27 Oct 2024 06:16:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Blood Pressure Monitor: Blood pressure monitor requires service]]></title>
<description><![CDATA[<p>My Microlite blood pressure testing machine the batteries are leaking I want to give for service. Can I get the address of service center in CHENNAI</p>
<p>⟐ Answer accepted 10월 20, 2024 at 10:20 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/791704/Blood+pressure+monitor+requires+service</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/791704</guid>
<pubDate>Sun, 20 Oct 2024 10:20:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Blood Pressure Monitor: How do I change the battery on a withings connect?]]></title>
<description><![CDATA[<p>So I want to change out the batteries on a used withings connect blood pressure cuff I bought on eBay.  I can’t get them above 74%.   It’s weird it’s one of the most popular wireless blood pressure monitors but there isn’t even a section.  Nothing else on the internet either.  There may be a reason for this.  Things like”DON’T!!  It will mess up the [insert reason here]” are acceptable</p>
<p>⟐ Edited by author 9월 25, 2024 at 15:50 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/870905/How+do+I+change+the+battery+on+a+withings+connect</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/870905</guid>
<pubDate>Wed, 25 Sep 2024 15:50:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Blood Pressure Monitor: Tycos palm sphygmomanometer VALVE not working after degreasing it]]></title>
<description><![CDATA[<p>My Tycos wasn’t used for many years and initially during deflating the needle was sort of bouncing.  I sprayed a degrease (CRC) in the valve and started working fine.  I thought that sticky black grease needed to be replaced so I sprayed more CRC until the whole was clean.</p>
<p>Unfortunately any grease that I added, including the super sticky PG-44A, did not revive the Tycos.  The valve act as an ON-OFF switch and it either closes completely when the screw is all in or opens completely at the minimal turn to unscrew it.  I cannot remove the valve, the nut seems to be glued to the chassis.  Tycos is a very expensive brand (over $450) and would like to repair it.  Any ideas?  Thank you.</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/719740/Tycos+palm+sphygmomanometer+VALVE+not+working+after+degreasing+it</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/719740</guid>
<pubDate>Tue, 25 Jan 2022 20:55:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Blood Pressure Monitor: How to fix disconnected mercury in sphygmomanometer]]></title>
<description><![CDATA[<p>My sphygmomanometer suddenly has its mercury disconnected,meaning that there are like air gaps in it,  which results in wrong readings, I think there is a way to fix it, but do not know how??</p>
<p>it's really important to me, and I almost daily need to use it. and do not want to buy another on.</p>
<p>⟐ Commented 12월 23, 2021 at 5:56 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/368104/How+to+fix+disconnected+mercury+in+sphygmomanometer</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/368104</guid>
<pubDate>Thu, 23 Dec 2021 05:56:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Blood Pressure Monitor: Why my new abpm not working]]></title>
<description><![CDATA[<p>new abpm monitor does not  turning on after installing batteries</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/701443/Why+my+new+abpm+not+working</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/701443</guid>
<pubDate>Thu, 05 Aug 2021 08:34:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Welch Allyn Blood Pressure Monitor: Welch allyn 300 series bp monitor]]></title>
<description><![CDATA[<p>It errors out upon insufflation. Tubing is good. I hear/se no leaks</p>
<p>⟐ Comment deleted 7월 02, 2021 at 9:53 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/684063/Welch+allyn+300+series+bp+monitor</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/684063</guid>
<pubDate>Fri, 02 Jul 2021 09:53:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Blood pressure monitor: I used 12v adaptor instead of 6v, now it has stopped working.]]></title>
<description><![CDATA[<p>Hi,</p>
<p>I used wrong 12v adapter instead of 6v in bp monitor, now it has stopped working. What to do now?</p>
<p>⟐ Commented 4월 20, 2021 at 3:36 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/458987/I+used+12v+adaptor+instead+of+6v,+now+it+has+stopped+working.</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/458987</guid>
<pubDate>Tue, 20 Apr 2021 03:36:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[Blood pressure monitor: Need a device that will monitor blood pressure during the day]]></title>
<description><![CDATA[<p>I having problems with adjusting my blood pressure medications.</p>
<p>Does anyone know of a wrist device that will monitor blood pressure during the day so that it will alert me to either check it with a sphygmomanometer or take my meds.</p>
<p>This would help prevent me from going off on rants while answering iFixit questions ;-)  And a lot of you are aware I can do that!</p>
<p><strong>UPDATE 9/21/18</strong></p>
<p>I was in hopes that the new iWatch 4 might help monitor my atrial fibrillation (aFib).  I was just about to order one but found this article stating that Apple has promised it for later:</p>
<p><strong>Buying an Apple Watch 4 now for EKG and AFib features may leave you heartbroken</strong></p>
<p><a href="https://www.zdnet.com/article/buying-an-apple-watch-4-now-for-ekg-and-afib-features-may-leave-you-heartbroken/" rel="nofollow noopener noreferrer" title="https://www.zdnet.com/article/buying-an-apple-watch-4-now-for-ekg-and-afib-features-may-leave-you-heartbroken/">https://www.zdnet.com/article/buying-an-...</a></p>
<p>⟐ Answered 6월 21, 2020 at 5:30 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/366615/Need+a+device+that+will+monitor+blood+pressure+during+the+day</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/366615</guid>
<pubDate>Sun, 21 Jun 2020 05:30:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Blood pressure monitor: How to fix er 37 on my omron blood presure monitor]]></title>
<description><![CDATA[<p>my Omron blood pressure monitor shown er 37</p>
<p>⟐ Commented 5월 29, 2020 at 18:31 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/489246/How+to+fix+er+37+on+my+omron+blood+presure+monitor</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/489246</guid>
<pubDate>Fri, 29 May 2020 18:31:26 -0700</pubDate>
</item>
</channel>
</rss>
