<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Kenwood Mixer&quot;]]></title>
<link>https://ko.ifixit.com/Answers/Device/Kenwood_Mixer?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Kenwood Mixer&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 09 Aug 2026 16:26:01 -0700</pubDate>
<item>
<title><![CDATA[Kenwood Chef A701A: Kenwood chef A701A schematics]]></title>
<description><![CDATA[<p>Where can I find the schematics for a Kenwood chef model A701A in order to  restore this machine?.</p>
<p>Mike Jordan.</p>
<p>⟐ Commented 12월 09, 2022 at 23:52 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/191531/Kenwood+chef+A701A+schematics</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/191531</guid>
<pubDate>Fri, 09 Dec 2022 23:52:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef A701A: Burning Smell but speed no problem]]></title>
<description><![CDATA[<p>Hi,</p>
<p>I just bought a 2nd hand Kenwood Chef A701A. It is working, the speed can be adjusted from one to max. However, there is burning smell but no smoke. How should I check on the motor and what to change?</p>
<p>Appreciate your reply.</p>
<p>⟐ Answer accepted 10월 04, 2024 at 8:37 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/277440/Burning+Smell+but+speed+no+problem</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/277440</guid>
<pubDate>Fri, 04 Oct 2024 08:37:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef: Oil leak top of machine]]></title>
<description><![CDATA[<p>Chef Premier.</p>
<p>Oil has appear inside the top cover around/ below the drive from the gear box to the electric motor, near to the blender drive.</p>
<p>⟐ Answer edited 10월 02, 2022 at 12:48 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/749863/Oil+leak+top+of+machine</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/749863</guid>
<pubDate>Sun, 02 Oct 2022 12:48:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef: How to replace/ clean the brushes in the Kenwood Chef- Titanium kmc010]]></title>
<description><![CDATA[<p>Dear readers,</p>
<p>I have the following problem (since yesterday) with my Kenwood Chef-Titanium kmc010 (3 years old);</p>
<p>When I started the engine, It's spinning around a bit but with shocks.</p>
<p>Sometimes he even does not run (continuous) and I need him cranking up.</p>
<p>The gear operates noticeably, but the engine does not come at the correct speed.</p>
<p>I think I have to clean the carbon-brushes. (there could be some leaked juice in it).</p>
<p>So, I decided to open the machine. (what I've been doing for years with broken machines)</p>
<p>After removal of the drive belt, the motor is still spinning around a bit with same shocks.</p>
<p>I note:</p>
<p>- The electronics (in the Speed Control Module) look fresh and do not stink or smoke.</p>
<p>The motor:</p>
<p>-The Small Pulley does not have a Tension Pin or Screw .. (see picture)</p>
<p>-The back fan also has no Tension Pin or screw ...</p>
<p>-The plastic motor-jacket is completely closed.</p>
<p>-There are 2 mounting screws in the chassis. After removal, everything is still stuck.</p>
<p>So the Pulley has to be removed? But how? Pulling, heating, striking, sawing?</p>
<p>Who can help me with this?</p>
<p>Thanks in advance.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/HWOSCXNgBjJgfDmX.standard" width="257" height="225" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/HWOSCXNgBjJgfDmX.full&quot;, '', 'width=500,height=438')" /></div>
<p>⟐ Edited 1월 22, 2024 at 7:51 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/425492/How+to+replace-+clean+the+brushes+in+the+Kenwood+Chef-+Titanium+kmc010</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/425492</guid>
<pubDate>Mon, 22 Jan 2024 07:51:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef A701A: Pinion drive gear in the gearbox]]></title>
<description><![CDATA[<p>I have the pinion drive gear out of the gearbox and it seems to be in good order with no splits on the cogs. However I notice the cog spins freely on the shaft and it seemed to me that the cog should be locked to the shaft in order to transmit power the remaining gears in the gearbox. The problem I am trying to fix is the motor running does not turn the planetary gears with any strength. They might start to turn a bit and then stall and don't turn.</p>
<p>⟐ Commented 2월 10, 2023 at 1:05 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/271915/Pinion+drive+gear+in+the+gearbox</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/271915</guid>
<pubDate>Fri, 10 Feb 2023 01:05:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef A701A: power goes on but engine will not speed up]]></title>
<description><![CDATA[<p>Engine works but does not increase speed when the speed dial is turned. continues at very low speed</p>
<p>⟐ Commented 2월 23, 2023 at 2:50 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/769303/power+goes+on+but+engine+will+not+speed+up</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/769303</guid>
<pubDate>Thu, 23 Feb 2023 02:50:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef: My kenwood chef (1991) stopps turning when food is in the bowl]]></title>
<description><![CDATA[<p>My Kenwood Chef (1991) does not rotate and unwinds the nut if the food mix is solid (even a  pastry mix). I have had it serviced about 10 years ago because this was happening but it still didnt rotate. Its fine with liquids (little resistance)</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/a4IygKjj5EWc2FIE.standard" width="169" height="225" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/a4IygKjj5EWc2FIE.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/Nqe5jAuwWnMIfO1U.standard" width="169" height="225" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/Nqe5jAuwWnMIfO1U.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/KLKFbHWxFEwyqKGY.standard" width="169" height="225" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/KLKFbHWxFEwyqKGY.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/bjrLINgnPmogaTY4.standard" width="282" height="211" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/bjrLINgnPmogaTY4.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/HXFUpkN2oeVkKjRy.standard" width="169" height="225" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/HXFUpkN2oeVkKjRy.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/OJbuCS615JmQnenB.standard" width="282" height="211" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/OJbuCS615JmQnenB.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/RfPJsEwp6DHHSFhk.standard" width="169" height="225" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/RfPJsEwp6DHHSFhk.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Commented 6월 19, 2022 at 16:47 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/737033/My+kenwood+chef+(1991)+stopps+turning+when+food+is+in+the+bowl</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/737033</guid>
<pubDate>Sun, 19 Jun 2022 16:47:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef A701A: Kenwood chef A701A not working]]></title>
<description><![CDATA[<p>I used my Kenwood, switched off. Then put another mixture in 10 mins later. Switched on but nothing happened. Will not go. Please advise what may be the problem. Thanks</p>
<p>⟐ Commented 2월 27, 2021 at 6:39 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/231106/Kenwood+chef+A701A+not+working</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/231106</guid>
<pubDate>Sat, 27 Feb 2021 06:39:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef: Speed governor not working]]></title>
<description><![CDATA[<p>Kenwood chef only runs at one fast speed</p>
<p>⟐ Answered 9월 28, 2019 at 8:52 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/593295/Speed+governor+not+working</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/593295</guid>
<pubDate>Sat, 28 Sep 2019 08:52:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Mixer: Why does kenwood Kmix not work at times when turned On speed switch?]]></title>
<description><![CDATA[<p>Why my Kenwood Kmx50 Kmix does not work at times when turned On the speed switch? At times it works but sometimes it just won't start. Some say that you need to wait for a few seconds and then start but it still does not work.</p>
<p>⟐ Edited by author 9월 01, 2020 at 16:29 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/652889/Why+does+kenwood+Kmix+not+work+at+times+when+turned+On+speed+switch</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/652889</guid>
<pubDate>Tue, 01 Sep 2020 16:29:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef: If the stand mixer only runs on the highest speed but not on medium]]></title>
<description><![CDATA[<p>My stand mixer only runs on the highest speed ,when I turn on the dial ,the switch knob it immediately runs on the last speed ,does not come down to medium or low speed ,what might have gone wrong ? Is it the PCB or just the speed knob / assembly?</p>
<p>Pls advice what is it ? I have accurately described the problem ,it is just THIS problem ,else the stand mixer works fine .</p>
<p>Many thanks ,</p>
<p>Kindly pls suggest</p>
<p>⟐ Commented 3월 13, 2022 at 21:08 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/435716/If+the+stand+mixer+only+runs+on+the+highest+speed+but+not+on+medium</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/435716</guid>
<pubDate>Sun, 13 Mar 2022 21:08:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef: How to open gear box for Kenwood Chef XL KVL40?]]></title>
<p>My Kenwood Chef XL is leaking oil from the gearbox.</p>
<p>According to this answer (<a href="/Answers/View/749863/Oil+leak+top+of+machine">Oil leak top of machine</a>), the grease in the gear box might have dissolved to oil, and as the gear box seems to be unsealed, that oil is leaking. If that's the diagnose, then the way to fix it would be, to either replace the gear box (which sounds appealingly easy), or to open that gearbox, clean it, and put grease in again.</p>
<p>Unfortunately, the technically easier way of purchasing a new gearbox seems to not be simple; they seem to be hard to get, and also not cheap. So, what remains, is the pathway to open it up, clean, re-grease, and (omg) re-assemble in a way that it works.</p>
<p>Ignoring my fear of having to re-assemble those potentially millions of tiny cogwheels that might await me under the hood, I firstly wonder now, how to open the gearbox: I can see 6 phillips screws, but two of them are hidden under a big white plastic cogwheel. The gap between the cogwheel and the screw head is only about 5mm, so not much chance to get a screwdriver in between. I have carefully tried to pull it up, but it sits pretty tight, and I have little desire to break it.</p>
<p>Does anyone have a hint?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/oZiqaAQC6fSW2LVW.standard" width="113" height="225" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/oZiqaAQC6fSW2LVW.full&quot;, '', 'width=695,height=1386')" /></div>
<p>⟐ Commented 6월 15, 2026 at 7:09 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/783777/How+to+open+gear+box+for+Kenwood+Chef+XL+KVL40</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/783777</guid>
<pubDate>Mon, 15 Jun 2026 07:09:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef A701A: Balloon whisk hub assembly service]]></title>
<description><![CDATA[<p>The balloon whisk in my a701a KENWOOD seemed to be misaligned.</p>
<p>I noticed a small flathead screw in the middle of the hub assembly naturally I figured I’d undo this and see what was inside. Turns out it’s quite hard to realign the wires and reinstall the hub. anyone have any tips? Should I be regressing the hub? Is there an order to the wires?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/dfTFYNV4VB5ZXEDS.standard" width="169" height="225" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/dfTFYNV4VB5ZXEDS.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/xEylc4LPS1HbbqqO.standard" width="169" height="225" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/xEylc4LPS1HbbqqO.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Commented 7월 15, 2023 at 18:43 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/801561/Balloon+whisk+hub+assembly+service</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/801561</guid>
<pubDate>Sat, 15 Jul 2023 18:43:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Mixer: Mixer speed is very slow]]></title>
<description><![CDATA[<p>My kenwood chef mixer has slowed down a lot….</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_08_08_Num_2019" class="header">Update (08/08/2019)</h3></div>
<p>Kenwood mixer only  moves when turn  know to number 4…then it is fast…</p>
<p>numbers 1 to 3 doesn’t operate at all.  What to do next?</p>
<p>Thank you</p>
<p>⟐ Commented 4월 05, 2024 at 0:15 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/581263/Mixer+speed+is+very+slow</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/581263</guid>
<pubDate>Fri, 05 Apr 2024 00:15:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef A701A: only works on high speed]]></title>
<description><![CDATA[<p>the speed only works on high speed regardless of  the setting</p>
<p>⟐ Answered 11월 28, 2021 at 0:33 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/713361/only+works+on+high+speed</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/713361</guid>
<pubDate>Sun, 28 Nov 2021 00:33:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef A701A: please can anyone advise on the number of shims on the motor armature]]></title>
<description><![CDATA[<p>how many shims are there on the motor armature at the bottom end near the control board?</p>
<p>I have removed the armature from the housing and I am not sure how many shims there were.</p>
<p>thanks</p>
<p>Bill24</p>
<p>⟐ Answer accepted 7월 08, 2021 at 10:12 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/657042/please+can+anyone+advise+on+the+number+of+shims+on+the+motor+armature</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/657042</guid>
<pubDate>Thu, 08 Jul 2021 10:12:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef: Clutch slip on Kenwood 701]]></title>
<description><![CDATA[<p>My Kenwood  chef  will not engage the motor unless I press down on the top plate. The teeth on the drive clutch will not engage. I cannnot see how to remove the cone topped drive from the gearbox. I am in Stranraer and there does not appear to be any Kenwood repairs in Scotland so any advice is welcome.</p>
<p>⟐ Edited 10월 19, 2018 at 6:24 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/523454/Clutch+slip+on+Kenwood+701</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/523454</guid>
<pubDate>Fri, 19 Oct 2018 06:24:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef A701A: Mixer opening when mixing]]></title>
<description><![CDATA[<p>My kenwood will just pop open when it’s mixing.  I have to hold it down.  It started doing this when I was mixing dough but will do it for anything now.</p>
<p>⟐ Answer accepted 11월 23, 2017 at 9:27 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/436855/Mixer+opening+when+mixing</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/436855</guid>
<pubDate>Thu, 23 Nov 2017 09:27:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Chef: Kenwood Chef XL Gearbox exploded view / washer positions]]></title>
<description><![CDATA[<p>Does anybody nlow where the top (#1) and the middle (#3)washer go?</p>
<p>Gearbox of a Chef XL, took it apart and these 2 came out of cleaning bucket at the end.</p>
<p>I am pretty certain that:</p>
<p>#2 (2 of them) go on the 2 middle gears, top</p>
<p>#4 bottom, driveshaft that connects to the slow speed</p>
<p>#5 slow speed</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/BkZugVIOkBRMMFie.standard" width="169" height="225" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/BkZugVIOkBRMMFie.huge&quot;, '', 'width=900,height=1200')" /></div>]]></description>
<link>https://ko.ifixit.com/Answers/View/906315/Kenwood+Chef+XL+Gearbox+exploded+view+-+washer+positions</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/906315</guid>
<pubDate>Sun, 06 Jul 2025 01:11:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kenwood Titanium Major (KMM060): How can I fix a stuck speed dial on a Kenwood Major?]]></title>
<description><![CDATA[<p>Hi!</p>
<p>I accidentally opened the latch while the machine was on high speed, now the speed dial is stuck on high speed.</p>
<p>Is this something I can repair myself?</p>
<p>Any help is much appreciated:)</p>
<p>⟐ Edited by author 8월 21, 2023 at 11:00 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/809123/How+can+I+fix+a+stuck+speed+dial+on+a+Kenwood+Major</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/809123</guid>
<pubDate>Mon, 21 Aug 2023 11:00:58 -0700</pubDate>
</item>
</channel>
</rss>
