<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;MacBook Pro 14&quot; 2021&quot;]]></title>
<link>https://ko.ifixit.com/Answers/Device/MacBook_Pro_14%22_2021/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;MacBook Pro 14&quot; 2021&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Thu, 09 Jul 2026 03:19:45 -0700</pubDate>
<item>
<title><![CDATA[MacBook Pro 14" 2021: Will swapping the battery show a 'service required' message?]]></title>
<description><![CDATA[<p>Im planning on swapping the original battery on my 14&quot; MacBook Pro as it's performance has degraded over the years, but I don't know if performing this will show the 'service required' message even after replacing it, similarly as is does when swapping out a display.</p>
<p>⟐ Answered 7월 02, 2026 at 14:53 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/962251/Will+swapping+the+battery+show+a+&#039;service+required&#039;+message</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/962251</guid>
<pubDate>Thu, 02 Jul 2026 14:53:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: MacBook Pro 14” 2021 (A2442, M1 Pro) — Adding thermal pads on heatsink]]></title>
<description><![CDATA[<p>Hi everyone,</p>
<p>I have a MacBook Pro 14-inch 2021 (A2442, M1 Pro) and I want to improve cooling with the easiest/safest method possible.</p>
<p>I don’t want to do a full logic board removal right now if I can avoid it. I’m planning the “add thermal pads” mod — placing high-conductivity thermal pads on top of the metal heatsink/radiator so heat transfers better to the aluminum bottom case (turning the whole bottom into an extra passive heatsink).</p>
<p>I’ve watched some of Your videos and others but there is not a video for my question (what i want).</p>
<p>My questions:</p>
<p>1.  For the easier bottom-case-only version, is 1.5mm or 2mm thick high W/mK pads (Thermalright / Gelid / Arctic style) the best choice? What size sheet should I get and where exactly on the heatsink should I place the pieces?</p>
<p>2.  I will leave Apple’s original grey paste on the main SoC and the black thermal gel (TCRS Carbon Black) on the RAM chips completely alone. I dont wanna touch them i want to add more too cool it down.</p>
<p>4.  What kind of real-world gains have people seen on the 14” M1 Pro specifically (temps, fan noise, sustained performance)?</p>
<p>5.  If the pad mod isn’t enough later, is the full heat sink replacement guide the right next step, and do you recommend Noctua NT-H2 or Arctic MX-6?</p>
<p>I will make pictures when i do this and share it with you here so people to know excactly what to do.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_06_25_Num_26" class="header">Update (06/25/26)</h3></div>
<p>I want to share my exp. With the chat bot i think i have all answers to my questions i have  what i need but you people can read as well and maybe my questions can help.</p>
<p>This is a conversation with AI asking question of how to apply thermal pads with Pics. And extra questions.</p>
<p>Venelin Valkanov</p>
<p><a href="https://fixbot.ifixit.com/chat/f9a4e89e-0ec7-48ae-8ceb-15521720957e" title="https://fixbot.ifixit.com/chat/f9a4e89e-0ec7-48ae-8ceb-15521720957e">https://fixbot.ifixit.com/chat/f9a4e89e-...</a></p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_06_25_Num_26_1" class="header">Update (06/25/26)</h3></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/mQ2AGaYnAtCQSx2u.standard" width="282" height="113" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/mQ2AGaYnAtCQSx2u.full&quot;, '', 'width=2566,height=1031')" /></div>
<p>Any ideas?</p>
<p>⟐ Answered 6월 25, 2026 at 6:30 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/961127/MacBook+Pro+14%E2%80%9D+2021+(A2442,+M1+Pro)+%E2%80%94+Adding+thermal+pads+on+heatsink</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/961127</guid>
<pubDate>Thu, 25 Jun 2026 06:30:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: Can I replace or fix the microphone?]]></title>
<description><![CDATA[<p>The microphone on my M1 Macbook Pro is very muffled.</p>
<p>After some investigation, I'm fairly sure the problem is a blocked grille. But it's hard to identify which (if any) of the hundreds of dimples on the left-hand side are actual holes and therefore need cleaning. Is there any information on this?</p>
<p>⟐ Commented 6월 06, 2026 at 9:59 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/946416/Can+I+replace+or+fix+the+microphone</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/946416</guid>
<pubDate>Sat, 06 Jun 2026 09:59:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: 14-inch MacBook Pro display: Staingate issue]]></title>
<p>I am noticing an issue with the display on my 14-inch MacBook Pro (Model A2442). There is a subtle but noticeable color shift happening across the screen. When viewing a pure white background, the affected areas look off-white/grayish. On dark backgrounds, there are permanent &quot;smudge&quot; marks that do not wipe away with a microfiber cloth.</p>
<p>It looks like the anti-reflective coating is failing or peeling (Staingate)?</p>
<p>Has anyone successfully stripped the coating on this specific 14-inch model without damaging the Mini-LED backlight or glass?</p>
<p>Any insights or advice would be greatly appreciated!</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/DTHKTQfU6X4xPSvV.standard" width="127" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/DTHKTQfU6X4xPSvV.huge&quot;, '', 'width=675,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/AHRUWTJtCZ6FXhKb.standard" width="144" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/AHRUWTJtCZ6FXhKb.huge&quot;, '', 'width=765,height=1200')" /></div>
<p>⟐ Commented 5월 27, 2026 at 14:51 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/956946/14-inch+MacBook+Pro+display:+Staingate+issue</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/956946</guid>
<pubDate>Wed, 27 May 2026 14:51:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: macOS 26.4 charge limiter not working, possibly due to replacement bat]]></title>
<description><![CDATA[<p>]Not sure if this has been reported on or if I just have a weird bug but for the life of me I cannot get the battery charge limiter to work. I thought it would be nice since I rarely use it for more than a few hours at a time and figured it could save me the hassle of replacing the battery again, or at least offset it. Admittedly I do not know if it is due to the battery being aftermarket or if it is just modern macOS doing modern macOS things, so I am just seeing if anyone has similar issues.Edit:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/4Q2RW1q6LSWb5Qwr.standard" width="282" height="183" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/4Q2RW1q6LSWb5Qwr.huge&quot;, '', 'width=1600,height=1040')" /></div>
<p>⟐ Commented 4월 07, 2026 at 19:53 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/949174/macOS+26.4+charge+limiter+not+working,+possibly+due+to+replacement+bat</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/949174</guid>
<pubDate>Tue, 07 Apr 2026 19:53:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: MacBook Pro 14” M1 Pro headphone jack crackling. Can someone help?]]></title>
<description><![CDATA[<p>Im lost. Is the problem the macbook or my headphones? The headphones and desktop speakers are the only aux device i have that i can try. And on desktop speakers i cant hear any crakling or loosing audio when plugged into macbook. On the headphones there is obvious audio drops. I tested the headphones on my old elitebook and they dont drop audio like this. I have a 30 day return window on this macbook so i would really want to know if this is normal or should i return it? it works normally when i dont move it, but if i move it it does this audio crackling</p>
<p>i added videos:<br /><a href="https://streamable.com/k715ir" rel="nofollow noopener noreferrer">headphones on macbook</a><br /><a href="https://streamable.com/k02mco" rel="nofollow noopener noreferrer">desktop speakers on macbook</a><br /><a href="https://streamable.com/o4phtn" rel="nofollow noopener noreferrer">same headphones on an old elitebook</a></p>
<p>⟐ Commented 3월 21, 2026 at 18:14 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/946119/MacBook+Pro+14%E2%80%9D+M1+Pro+headphone+jack+crackling.+Can+someone+help</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/946119</guid>
<pubDate>Sat, 21 Mar 2026 18:14:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: Display issues on MacBook Pro 14" M1 - Shadows on Screen]]></title>
<description><![CDATA[<p>Hi, I replaced the logic board on my macbook pro 14 M1 and now it shows shadows on the top side of the screen besides the notch. I tried with different displays and same problem. Does anyone have the same issue?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/YJMaPhwOEdsPlQrB.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/YJMaPhwOEdsPlQrB.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/aFWoYPAHkWbonsPr.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/aFWoYPAHkWbonsPr.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/WyaOTh3xASCnQtit.standard" width="282" height="192" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/WyaOTh3xASCnQtit.huge&quot;, '', 'width=1600,height=1091')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/nLSSRfjAIIStrLgL.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/nLSSRfjAIIStrLgL.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>⟐ Answered 3월 13, 2026 at 20:40 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/744273/Display+issues+on+MacBook+Pro+14%22+M1+-+Shadows+on+Screen</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/744273</guid>
<pubDate>Fri, 13 Mar 2026 20:40:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: New ifixit battery won't charge]]></title>
<description><![CDATA[<p>I've just installed a new ifixit battery (from the &quot;MacBook Pro 14&quot; (A2442, A2779, A2918) Battery&quot; ******kit). My macbook recognises it as a new battery because the health is 100%, compared to my last battery which was around 70%. After I first installed the battery and plugged it in, it immediately said it was at 62% battery and would not charge at all. I left it charging for two hours and shut it down for long periods of time, but nothing has worked so far.</p>
<p>⟐ Commented 3월 06, 2026 at 5:00 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/943478/New+ifixit+battery+won&#039;t+charge</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/943478</guid>
<pubDate>Fri, 06 Mar 2026 05:00:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: My keyboard has been damaged]]></title>
<description><![CDATA[<p>My macbook keyboard has been damaged somehow, how would i fix it without paying 1100 dollars apple charges for a replacement, and my mac squeeks when i open it.</p>
<p>⟐ Commented 2월 13, 2026 at 6:24 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/725525/My+keyboard+has+been+damaged</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/725525</guid>
<pubDate>Fri, 13 Feb 2026 06:24:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: Runaway cursor and click after battery replacement]]></title>
<description><![CDATA[<p>I replaced the battery on a 2021 MacbookPro. Now, I have functionality, but the cursor/trackpad will suddenly runaway, and/or click in rapid fashion. I have to use a key to stop it. I will recheck cables and connection tapes, but if anyone else has any ideas please let me know.</p>
<p>⟐ Answered 1월 12, 2026 at 19:32 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/935683/Runaway+cursor+and+click+after+battery+replacement</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/935683</guid>
<pubDate>Mon, 12 Jan 2026 19:32:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: does tesa tape 66822 really required on LCD only replacement?]]></title>
<description><![CDATA[<p>dear all,</p>
<p>macbook pro 14 inch 2021 a2442, i already bought the LCD only panel, but no steel bracket</p>
<p>i find guides on youtube guys telling to stick the old bracket to new LCD with tesa tape model 66822, but i can't buy it in my country, can i just use 3M tissue tape?</p>
<p>or it will risk cracking the LCD glass on assembly process cause by pressure or movement while fitting it into bezel?</p>
<p>any tape suggested to use around the bezel surrounding LCD also? i see it was so thin</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_12_22_Num_25" class="header">Update (12/22/25)</h3></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/iADaoYEwjxhvLClE.standard" width="104" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/iADaoYEwjxhvLClE.full&quot;, '', 'width=1284,height=2778')" /></div>
<p>⟐ Answer unaccepted 1월 07, 2026 at 4:24 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/931904/does+tesa+tape+66822+really+required+on+LCD+only+replacement</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/931904</guid>
<pubDate>Wed, 07 Jan 2026 04:24:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: How to remove keyboard keycap?]]></title>
<description><![CDATA[<p>Something is stuck under my number “1” key. How can I remove keycap.</p>
<p>⟐ Commented 12월 23, 2025 at 4:34 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/721563/How+to+remove+keyboard+keycap</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/721563</guid>
<pubDate>Tue, 23 Dec 2025 04:34:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: Why is my MacBook not turning on?]]></title>
<description><![CDATA[<p>Macbook not turning on. MagSafe charging LED not showing and usb c charging does not seems to work.</p>
<p>Left connected to dock with power delivery via usb c for 24-36 hours and when I came back it doesn't want to turn on</p>
<p>⟐ Answered 12월 17, 2025 at 6:58 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/925645/Why+is+my+MacBook+not+turning+on</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/925645</guid>
<pubDate>Wed, 17 Dec 2025 06:58:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: "Service Recommended" after new battery install]]></title>
<description><![CDATA[<p>I replaced my battery in my 2021 14&quot; Macbook Pro. Fairly simple with no issues..Now it shows the cycle count reset to 3 which is correct, the power remaining which is also correct but it still states &quot;Service Recommended&quot;.<br /> Is there another reset I need to do?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/4kLMfiNCs5mM4r5L.standard" width="199" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/4kLMfiNCs5mM4r5L.full&quot;, '', 'width=1077,height=1223')" /></div>
<p>⟐ Answered 11월 28, 2025 at 17:25 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/928358/%22Service+Recommended%22+after+new+battery+install</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/928358</guid>
<pubDate>Fri, 28 Nov 2025 17:25:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: Trackpad rubbing screen after battery replacement]]></title>
<description><![CDATA[<p>I recently did a battery replacement on my 2021 14&quot; MacBook Pro. Part of that procedure involves removing the trackpad, which I did. I thought I had secured it correctly, but it seems that the trackpad may have been sitting a little too high up, and it has rubbed against the screen, which makes it appear there is a constant smudge. I've obviously tried cleaning it off, to no avail.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/LiHQhXDVdkBATdbK.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/LiHQhXDVdkBATdbK.full&quot;, '', 'width=1280,height=960')" /></div>
<p><br /><br />Last night I took the trackpad out again and did my best to reseat it correctly.<br /><br /></p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/CEMMHf1fPRwvCfGg.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/CEMMHf1fPRwvCfGg.full&quot;, '', 'width=1280,height=960')" /></div>
<p><br /><br />I'm still not sure if it's correct--compared to my work laptop (a 2024 MacBook Air) the trackpad is clearly indented a fraction of a millimeter -- you can feel it with your fingers when you swipe off the trackpad. On my MacBook Pro, some edges of the trackpad feel like they are underneath the chassis, while others (especially the bottom right corner of the trackpad) feel perfectly flat with the chassis. <br /><br />Some questions:<br /><br />1. What is normal for a 2021 MacBook Pro? Should the trackpad be slightly indented below the chassis? (P.S. this is why the repair manual needs more than just &quot;do it in reverse&quot;)<br />2. As I have things now, is it likely that the trackpad is still rubbing on the screen? I'm probably going to want to replace the screen now, and I don't want to spend $500 and then ruin the new screen because the trackpad still isn't right.<br />3. If the trackpad is wrong, how can I get it lower? I've already tried reseating it, and it does not seem to want to go any lower in the chassis. Am I missing something?</p>
<p>⟐ Commented 11월 05, 2025 at 15:11 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/924994/Trackpad+rubbing+screen+after+battery+replacement</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/924994</guid>
<pubDate>Wed, 05 Nov 2025 15:11:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: Power issues with both MagSafe and USB-C ports]]></title>
<description><![CDATA[<p>I had a problem with my MacBook pro 2021. M1 chip and was only using it about a year when I was having problems where it wouldn't charge.</p>
<p>So I sent it to some guy on YouTube or company on YouTube in Virginia. They charged me $200 to tell me that I need to have parts replaced on the circuit board that will cost me over $1,000 or $600. And then I found the guy on eBay and he's been working on my laptop and said that there were about four capacitors that shorted out.</p>
<p>So I think that your problem's probably related to bad capacitors. It could be shorting out the rest of the board so it's best not to have it plugged up at all. And if you're looking to have somebody fix it, you probably will have to pay about $300 to $400 if you go with somebody off of eBay</p>
<p>⟐ Answered 11월 03, 2025 at 17:21 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/924696/Power+issues+with+both+MagSafe+and+USB-C+ports</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/924696</guid>
<pubDate>Mon, 03 Nov 2025 17:21:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: MacBook Pro 14-inch M1 Not Charging via MagSafe or USB-C]]></title>
<description><![CDATA[<p>My MacBook Pro 14-inch M1 refuses to charge, whether I use MagSafe or USB-C. It only charges very slowly when the MacBook is powered off. When it's on, the LED stays orange (without blinking), but there’s no charging happening.</p>
<p>I also found that one of the USB-C ports on the left side isn’t functioning at all—it doesn’t detect USB drives, while the other USB-C port works fine (though still no charging).</p>
<p>I followed tutorials and opened the MacBook, but everything looks intact. All the ports appear undamaged, and there’s no visible wear or issue.</p>
<p>This problem started suddenly, with no prior warning or incidents. I’ve been using the official Apple charger and cable.</p>
<p>As part of troubleshooting, I tried downgrading macOS using another Mac, but that didn’t help. I've also tried replacing the faulty usb-c and MagSafe connectors with ones from a working MacBook Pro, but the issue persists. I’m starting to suspect that the logic board is the problem, even though I haven’t done anything to damage the Mac.</p>
<p>At the moment, the battery is at 100%, and the MagSafe LED is green, but the Mac still isn’t recognizing the Apple Power Adapter (see attached photo).</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/LH3sk66PtKDZYbnO.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/LH3sk66PtKDZYbnO.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>Do you have any suggestions on how to proceed?</p>
<p>⟐ Commented 11월 03, 2025 at 14:42 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/877456/MacBook+Pro+14-inch+M1+Not+Charging+via+MagSafe+or+USB-C</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/877456</guid>
<pubDate>Mon, 03 Nov 2025 14:42:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: Magsafe 3 blinking orange slowly and Mac not turning on]]></title>
<description><![CDATA[<p>My MacBook Pro M1 Pro (A2442) recently stopped turning on. Whenever I try to charge it the Magsafe 3 led blinks slowly in orange and even if I leave it for 30+ min it doesn't turn on. I have tried with USB c charging as well and it doesn't turn on.</p>
<p>I haven't used this Mac much so I usually only turn it on every month and the battery is dead so I have to charge it for 10 min or more before it can turn on on 1% battery and I can use it. I also usually don't turn it off and I guess it turns itself off by running out of battery.</p>
<p>Do I need to change the battery or how can I what's wrong with it ?</p>
<p>⟐ Commented 11월 02, 2025 at 4:45 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/902203/Magsafe+3+blinking+orange+slowly+and+Mac+not+turning+on</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/902203</guid>
<pubDate>Sun, 02 Nov 2025 04:45:55 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: New speaker for MacBook Pro early 2021]]></title>
<description><![CDATA[<p>My speaker broke, were can I buy a legit new one to repair it?</p>
<p>Thank you</p>
<p>⟐ Answer edited 10월 27, 2025 at 6:34 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/923565/New+speaker+for+MacBook+Pro+early+2021</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/923565</guid>
<pubDate>Mon, 27 Oct 2025 06:34:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 14" 2021: Return/Enter Key intermittently working, after battery replacement]]></title>
<description><![CDATA[<p>I just used a ifixit battery kit to replace the battery, everything went fine (except most strips broke, and I had to use the alcohol to remove them). The battery is working great and it looks like everything is good except the return key is not working at all. And the key was working for 4 years.</p>
<p>What i notice when i boot and i need to enter the password, the return key get triggered 1x (because the password prompt is shaking), i installed karabiner_elements to rebind the right shift key to return, and i got a error message that it looks like the return/enter key is hold down.</p>
<p>I opened the mac again and reseated the keyboard cable (i didn't touched it before), but no change. i started in diagnostic mode and the return key is not working as well.</p>
<p>Is there maybe a common issue/fix? the issue started directly after the repair and i used the macbook just before and after the repair</p>
<p><strong>EDIT:</strong> the situation changed... now the return key virtually pressed down all the time</p>
<p>when i press the return key, it goes back to normal. after some seconds (5-40) the</p>
<p>return key pressed down again(like holding the key down)</p>
<p>i don't  have to touch anything, it just happens and make using the mac impossible (as a workaround i disabled the return key with karabiner elements)</p>
<p>⟐ Answer edited 10월 26, 2025 at 15:45 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/923285/Return-Enter+Key+intermittently+working,+after+battery+replacement</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/923285</guid>
<pubDate>Sun, 26 Oct 2025 15:45:13 -0700</pubDate>
</item>
</channel>
</rss>
