<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Ryobi Power Drill&quot;]]></title>
<link>https://ko.ifixit.com/Answers/Device/Ryobi_Power_Drill?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Ryobi Power Drill&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 19 Jul 2026 17:41:29 -0700</pubDate>
<item>
<title><![CDATA[Ryobi P202: Drill will run for only a few seconds]]></title>
<description><![CDATA[<p>When you pull the trigger the drill only runs a short time and stops. Releasing the trigger and re-pulling it does nothing. If you release the trigger and switch direction, then pull the trigger it run but again only for a few seconds.</p>
<p>⟐ Answered 10월 23, 2025 at 21:29 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/294167/Drill+will+run+for+only+a+few+seconds</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/294167</guid>
<pubDate>Thu, 23 Oct 2025 21:29:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ryobi P202: release the chuck with stuck drill bit]]></title>
<description><![CDATA[<p>I have a stuck drill bit in the chuck. How can I release it?</p>
<p>⟐ Commented 9월 22, 2024 at 2:34 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/389038/release+the+chuck+with+stuck+drill+bit</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/389038</guid>
<pubDate>Sun, 22 Sep 2024 02:34:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ryobi P202: Why does the drill no longer work, but the led blinks 5 times?]]></title>
<description><![CDATA[<p>I used the drill for one full charge, then removed the battery and charged it.  After installing the battery, the drill no longer works.  The LED light on the front end blinks 5 times when depressing the trigger, but will not blink again until I remove the battery, reinstall and depress the trigger again.  I’ve tried 4 different Ryobi batteries all with the same result.</p>
<p>⟐ Commented 7월 05, 2020 at 7:18 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/556423/Why+does+the+drill+no+longer+work,+but+the+led+blinks+5+times</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/556423</guid>
<pubDate>Sun, 05 Jul 2020 07:18:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ryobi P202: Why is the drill wobbling when in use?]]></title>
<description><![CDATA[<p>When I use the drill to drive or remove screws, the drill shakes at different rates depending on the speed that I am drilling.  There symptoms occur in both the clockwise and counter-clockwise direction.  What should I do to repair this drill.</p>
<p>⟐ Answered 6월 28, 2018 at 6:27 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/224638/Why+is+the+drill+wobbling+when+in+use</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/224638</guid>
<pubDate>Thu, 28 Jun 2018 06:27:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ryobi P202: Why is the drill making strange clicking sounds when in use?]]></title>
<description><![CDATA[<p>When I use the drill it is making clicking sounds.</p>
<p>⟐ Commented 6월 23, 2023 at 8:32 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/225266/Why+is+the+drill+making+strange+clicking+sounds+when+in+use</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/225266</guid>
<pubDate>Fri, 23 Jun 2023 08:32:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ryobi P202: Why can't I depress the trigger?]]></title>
<description><![CDATA[<p>I am unable to depress the trigger on my drill.  I have changed the battery and the chuck spins normally when moved manually.</p>
<p>⟐ Comment deleted 6월 03, 2015 at 14:19 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/225191/Why+can&#039;t+I+depress+the+trigger</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/225191</guid>
<pubDate>Wed, 03 Jun 2015 14:19:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ryobi Brushless DrillDriver P252 2018: Can I lubricate my drill?]]></title>
<description><![CDATA[<p>Sometimes my drill squeals. Can I lubricate it?</p>
<p>⟐ Answered 8월 07, 2025 at 16:46 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/910806/Can+I+lubricate+my+drill</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/910806</guid>
<pubDate>Thu, 07 Aug 2025 16:46:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ryobi P202: Drill just stopped working]]></title>
<description><![CDATA[<p>Brand new drill. Used it a handful of times. Just stopped working while I was using it. Charged both batteries and still does nothing.  Never got wet or dropped.</p>
<p>⟐ Commented 1월 28, 2024 at 11:09 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/348202/Drill+just+stopped+working</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/348202</guid>
<pubDate>Sun, 28 Jan 2024 11:09:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ryobi Power Drill: Where to start? Ryobi LSD120]]></title>
<description><![CDATA[<p>I have a very old compact drill that has served me very well. But it’s died.  I would like to fix it. I have recharged both batteries and swapped them out: nothing. It was working ok then just stopped - no sign of anything going wrong beforehand. Where do I start with identifying what’s wrong? Any suggestions as to most likely causes of the problem?</p>
<p>⟐ Edited 12월 22, 2025 at 9:37 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/691696/Where+to+start+Ryobi+LSD120</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/691696</guid>
<pubDate>Mon, 22 Dec 2025 09:37:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ryobi DrillCordless P208B 2014: How to connect two wiring from motor to trigger switch]]></title>
<description><![CDATA[<p>how to connect two wiring from motor to trigger switch</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/888650/How+to+connect+two+wiring+from+motor+to+trigger+switch</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/888650</guid>
<pubDate>Thu, 20 Feb 2025 22:21:11 -0700</pubDate>
</item>
</channel>
</rss>
