<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Samsung Vacuum&quot;]]></title>
<link>https://ko.ifixit.com/Answers/Device/Samsung_Vacuum?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Samsung Vacuum&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 27 Jul 2026 19:19:17 -0700</pubDate>
<item>
<title><![CDATA[Samsung NaviBot SR8855: circuit diagram or schematic for accu loading]]></title>
<description><![CDATA[<p>The Bot Device cannot load his accu.</p>
<p>It does not recognized the contacts of the docking station. It still search and find the docking station well, but search endless the loading contacts.</p>
<p>I'm still good in electronics but do not have any schematics and don't kow any about the firmware/programms  of a lot of microcontroller build in.</p>
<p>⟐ Commented 7월 22, 2017 at 10:15 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/147881/circuit+diagram+or+schematic+for+accu+loading</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/147881</guid>
<pubDate>Sat, 22 Jul 2017 10:15:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Jet Bot VR30T80313W: Battery won't charge.]]></title>
<description><![CDATA[<p>So I just got my robot vacuum back after lending it to my brother.</p>
<p>Turned out it stopped working a while ago.</p>
<p>When I got it back I started to diagnose it.</p>
<p>The first thing I noticed was, when it's docked in the charginstation, it turns on and I can adopt it into the smart things app. The battery read 0% and no matter how long it charges it wouldn't go up.</p>
<p>So I started by disassembling the battery down to its individual cells. Turned out 5 out if 6 cells were completely dead (absolute 0 volts).</p>
<p>So I ordered some new cells and put the battery back together. The battery now shows 21,7 volts. But it still doesn't want to run outside the chargingstation.</p>
<p>When I use a multimeter on the battery, while it's connected to the chargingstation it shows about 25 volts on d+ to d- (the plugs from the vacuum to the PCB on the battery). And still 21,7 volts on b+ to b- (the spot welded tin to the battery). It has now charged for about 2 hours and it's still about 37% charged (so not getting charged).</p>
<p>I've tried to put the PCB under an thermal camera to see if anything gets hot, but it doesn't. Even with it plugged into the chargingstation, without the chargingstation or it disconnected from the robot. I've also tried to connect 21 volts 1 a with a powersupply connected both on d+ to d- and on b+ to b-, yet nothing gets hot.</p>
<p>Anyone have any idea on how I could fix this?</p>
<p>I'm pretty new to this stuff, but I do watch some youtubers like NorthridgeFix and TronicFix so I have some general idea.</p>
<p>Should I disconnect the cells again and maybe try injecting voltage over some of the chips on the PCB or check the resistance on some of the caps? If so i would love some guidence. I don't have a chip programmer yet, but I will order one sooner or later, if needed.</p>
<p>Image of the PCB here:</p>
<p><a href="https://imgur.com/a/eqJpynu" rel="nofollow noopener noreferrer">https://imgur.com/a/eqJpynu</a></p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/sqjQgBGZTZO2FDQW.standard" width="282" height="217" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/sqjQgBGZTZO2FDQW.huge&quot;, '', 'width=1557,height=1200')" /></div>
<p>I'm also working on a guide on the disassembly of the batter here (ask and ill add you in order to view):</p>
<p><a href="/Guide/Disassembling+Samsung+Vacuum+Battery+VCA-RBT80+VR30T80313W-WA/199862">Disassembling Samsung Vacuum Battery VCA-RBT80 VR30T80313W/WA</a></p>
<p>⟐ Commented 6월 16, 2026 at 3:16 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/925332/Battery+won&#039;t+charge.</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/925332</guid>
<pubDate>Tue, 16 Jun 2026 03:16:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung POWERbot R7070: PowerBot R7040 Runs with disengaged powerbrush]]></title>
<description><![CDATA[<p>my powerbot recently started to show this glitch where it actually runs pretending like it is cleaning but without actually vacuuming anything.(no powerbrush running) If i hit pause and then start again it starts and runs as expected. I’m not sure how often does this happen since it cleans mostly when I’m not home. I was only able to catch this on weekend.</p>
<p>⟐ Answered 6월 04, 2024 at 17:23 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/530334/PowerBot+R7040+Runs+with+disengaged+powerbrush</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/530334</guid>
<pubDate>Tue, 04 Jun 2024 17:23:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung NaviBot SR8855: How to disassemble Samsung navibot SR8875?]]></title>
<description><![CDATA[<p>Hi,</p>
<p>Would like to know how to remove the upper part of the navibot SR8875 ? I removed all screww but still locked in the front ?</p>
<p>If you want, you can also answer me in french (if you're french).</p>
<p>Thanks,</p>
<p>Matt</p>
<p>⟐ Answer accepted 12월 19, 2023 at 6:30 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/214152/How+to+disassemble+Samsung+navibot+SR8875</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/214152</guid>
<pubDate>Tue, 19 Dec 2023 06:30:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Powerbot R9250: Water vacuumed up - vacuum stopped working]]></title>
<description><![CDATA[<p>My Sammy is dead!  Sammy sucked up some water and quit working.  I dried it out by setting it out in warm weather and in the  sun and cannot get it to come back on or connect to the recharge station.  I have switched it off and on and done numerous things but no luck.  I have done all kinds of internal checks but cannot see anything to trip other than the master switch.  Is there a fuse or something else I need to check to restart.  I did not see very much water in the dust bin.</p>
<p>⟐ Answered 8월 15, 2020 at 17:45 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/500457/Water+vacuumed+up+-+vacuum+stopped+working</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/500457</guid>
<pubDate>Sat, 15 Aug 2020 17:45:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung NaviBot SR8855: Why does my navibot dont switch on?the battery is charged, but no ligh]]></title>
<description><![CDATA[<p>My navibot Doesn't switch on. The Battery is charged but  all lights are off. I tried to Clean it but Nothing changes.</p>
<p>⟐ Commented 11월 22, 2025 at 5:01 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/430240/Why+does+my+navibot+dont+switch+onthe+battery+is+charged,+but+no+ligh</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/430240</guid>
<pubDate>Sat, 22 Nov 2025 05:01:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung POWERbot R7070: Left wheel is not working properly]]></title>
<description><![CDATA[<p>I recently bought a refurbished powerbot r7070 and the left wheel stopped working. Everything was great for about a week before this issue occurred. I was hoping it was a minor issue but when i opened it up i couldn't see any jam or other visible issues. I am assuming it is the motor for that wheel. I called samsung and they dont sell parts for this model anymore.... So i am not sure what to do. I love the vaccum and i can get a refund for it but i got it at a once in a lifetime deal and would have to pay hundreds more for the same model =/</p>
<p>⟐ Commented 1월 15, 2021 at 13:51 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/446682/Left+wheel+is+not+working+properly</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/446682</guid>
<pubDate>Fri, 15 Jan 2021 13:51:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung NaviBot SR8855: Short shift and turn.]]></title>
<description><![CDATA[<p>Navibot sr8855 after repair of FET tranzistors for  brush have bad mooving - navigation.</p>
<p>From the beginning it worked well and after some time was problem in navigation.</p>
<p>It looks like that: move 20-30cm stop and go back about 3cm, turn 90st. and repeat.</p>
<p>Sometimes work good for 1 minute and then again fail to this state.</p>
<p>I try test mod and all sensors look fine, motors are OK too.</p>
<p>⟐ Commented 4월 21, 2017 at 10:36 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/243651/Short+shift+and+turn.</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/243651</guid>
<pubDate>Fri, 21 Apr 2017 10:36:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Powerbot R9250: My power bot is just blinking when I try to charge it. do you repair?]]></title>
<description><![CDATA[<p>I have a Samsung powerbot and it just stopped working one day. I have tried to replace the battery and the charging station but it does the same thing. When I move the powerbot to the charging station by hand, it starts to blink when on the charger. Then after a few mins it stops and will not charge. I am unsure if it is a fuse or what but I am looking for someone who can help fix it or someone who will repair it. I have contacted Samsung but they company they refered me to does not do repairs. It is just over a year old so there for my warranty is no good any more. Is there some place that will work on them or is there someone who knows how to fix it?</p>
<p>⟐ Commented 7월 10, 2025 at 10:14 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/564711/My+power+bot+is+just+blinking+when+I+try+to+charge+it.+do+you+repair</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/564711</guid>
<pubDate>Thu, 10 Jul 2025 10:14:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung POWERbot VR9000: Where can I find an affordable vr9000 battery replacement?]]></title>
<description><![CDATA[<p>I have a VR9000 samsung robot which I love.. only problem is the battery has now begun to not hold its charge for very long. I have looked online and can find nothing for less than AU $300 which just seems far to high for a Battery.</p>
<p>Is there any other alternatives or sites i can buy an aftermarket or second hand battery?</p>
<p>I live in Australia</p>
<p>Thanks</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/548444/Where+can+I+find+an+affordable+vr9000+battery+replacement</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/548444</guid>
<pubDate>Mon, 11 Feb 2019 02:18:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung NaviBot SR8855: Navibot from Korea change language to English.]]></title>
<description><![CDATA[<p>I have a Navibot VC-RL84VR from Korea and it only speaks Korean with its voice announcer.</p>
<p>Does anyone know how to switch it to English?</p>
<p>⟐ Answer accepted 11월 22, 2018 at 5:00 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/530359/Navibot+from+Korea+change+language+to+English.</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/530359</guid>
<pubDate>Thu, 22 Nov 2018 05:00:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung POWERbot VR9000: Making a strange noise]]></title>
<description><![CDATA[<p>Samsung power bot vacuum needs service. Where do I send it to get fixed?</p>
<p>⟐ Answered 7월 10, 2025 at 10:17 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/420730/Making+a+strange+noise</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/420730</guid>
<pubDate>Thu, 10 Jul 2025 10:17:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung POWERbot VR9000: How do I delete floor plans in the app?]]></title>
<description><![CDATA[<p>I have 6 floor plans in the app five of which are no good. Every time I try to pick the one I want it switches back to one I don't want.</p>
<p>⟐ Answered 7월 10, 2025 at 10:14 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/665902/How+do+I+delete+floor+plans+in+the+app</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/665902</guid>
<pubDate>Thu, 10 Jul 2025 10:14:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung POWERbot VR9000: How can I reset the Samsung Powerbot VR9000 computer?]]></title>
<description><![CDATA[<p>first I had a C06 error message, and my docking station green light was blinking and not charging.  After cleaning all sensors and the brush very well, I turned the unit off and on as instructions stated.  Now I either get a C01 error message or it just docks itself and acts like its charging but never really does.   Is there a way to reset the computer in the unit?</p>
<p>⟐ Commented 3월 18, 2021 at 10:17 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/575020/How+can+I+reset+the+Samsung+Powerbot+VR9000+computer</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/575020</guid>
<pubDate>Thu, 18 Mar 2021 10:17:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung NaviBot SR8855: Please help me. My samsung Navibot VC-RL84VR wont start]]></title>
<description><![CDATA[<p>After i disassmble the robot for a simple DIY wheels uplift so that it can handle a wet floor instead of stocking and sliping . when i reassemble it and turn it On. the only thing it do is to count 5 4 3 2 1 and flash the 1bar battery sign. then count again over and over. but i promiss i never did anything aside from uplifting the wheel and o never touch anything on the motherboard aside from removing the wheels and other connectors from the side part of the mother board. and i asure that everything is in contact even tested it and everything is in good contact even the battery is 16v when tested. please tel me what is wrong with this robot. you know i cant live without it. after many so many years its been a part of my small family. please help me</p>
<p>⟐ Commented 11월 06, 2019 at 13:24 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/529985/Please+help+me.+My+samsung+Navibot+VC-RL84VR+wont+start</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/529985</guid>
<pubDate>Wed, 06 Nov 2019 13:24:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung NaviBot SR8855: How to disassemble the charger?]]></title>
<description><![CDATA[<p>By any chance is there a step by step guide how to disassemble the charger? I mean the charging station not the robo itself. I figured out to remove all part but not able to open the big black main unit where actually the fuse and co. is placed :)</p>
<p>⟐ Answer accepted 11월 15, 2018 at 7:11 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/413701/How+to+disassemble+the+charger</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/413701</guid>
<pubDate>Thu, 15 Nov 2018 07:11:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung POWERbot R7070: Powerbot won't turn on at all]]></title>
<description><![CDATA[<p>I have had my Powerbot R7070 for a bit over a year now, so it’s no longer covered by warranty.</p>
<p>Recently it stopped turning on, and I was told the problem would likely be with the battery. So, I ordered a new battery and replaced it.</p>
<p>The powerbot still won’t turn on.</p>
<p>I have followed directions on samsung’s support website, about letting it charge for a while, then toggling the emergency switch off and back on, then holding down the start button, but there’s no indication of the powerbot getting any power.</p>
<p>I also checked the charging dock’s charging pins with a multimeter, and it seems to be working fine, so something is wrong with the vacuum itself.</p>
<p>Any ideas?</p>
<p>⟐ Commented 6월 16, 2019 at 17:03 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/572150/Powerbot+won&#039;t+turn+on+at+all</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/572150</guid>
<pubDate>Sun, 16 Jun 2019 17:03:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Powerbot R9250: power brush is rattling loudly when running]]></title>
<description><![CDATA[<p>the power bar is making a very loud rattling noise when running. When I take the brush out of the unit, the noise stops</p>
<p>⟐ Answer edited 10월 04, 2020 at 9:17 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/432701/power+brush+is+rattling+loudly+when+running</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/432701</guid>
<pubDate>Sun, 04 Oct 2020 09:17:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung POWERbot R7070: Cyclone fan is not spinning]]></title>
<description><![CDATA[<p>The little fan inside the dust bin isn't spinning, so debris isn't being pulled all the way into the bin. I tried turning it manually, but it's stuck in place. Does anyone know how to fix this issue?</p>
<p>⟐ Answered 9월 17, 2025 at 8:32 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/917659/Cyclone+fan+is+not+spinning</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/917659</guid>
<pubDate>Wed, 17 Sep 2025 08:32:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung POWERbot VR9000: The main board does not control the battery charge.]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/NNgF2HxDAwCjWmkY.standard" width="155" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/NNgF2HxDAwCjWmkY.full&quot;, '', 'width=1089,height=1581')" /></div>
<p>The main board does not control the battery. It always shows one digit of charge. The battery is brand new. I noticed that R109, R107 have different values. Do you have a circuit diagram of the main board or tell me the values of resistors R109, R107. Thank you.</p>
<p>⟐ Answered 7월 10, 2025 at 10:20 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/894037/The+main+board+does+not+control+the+battery+charge.</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/894037</guid>
<pubDate>Thu, 10 Jul 2025 10:20:58 -0700</pubDate>
</item>
</channel>
</rss>
