<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Samsung Washing Machine&quot;]]></title>
<link>https://ko.ifixit.com/Answers/Device/Samsung_Washing_Machine?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Samsung Washing Machine&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Thu, 03 Sep 2026 01:21:51 -0700</pubDate>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: Washing machine door won't unlock?]]></title>
<description><![CDATA[<p>My washing machine cycle came to an end. After 3 minutes it is supposed to unlock, but it didnt. It has drained all the water out, so that's not a problem. I turned the power off on the wall, and it still wouldnt unlock. How can I get my wet washing out?</p>
<p>⟐ Commented 8월 02, 2023 at 12:09 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/83303/Washing+machine+door+won&#039;t+unlock</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/83303</guid>
<pubDate>Wed, 02 Aug 2023 12:09:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine: Samsung washer no power at all suddently]]></title>
<description><![CDATA[<p>Hi, could someone give me a hint? This is Samsung front washer, model WF203ANS/XAC, about 5 years old. Never had problem but after we loaded it and believed it had worked for a while (could turn it on, seeing the led lights). Then we found it is dead and no responding to any buttons. The door was locked with clothes and water inside!</p>
<p>I have opened it almost everything and managed to take it front face off and got the clothes out.</p>
<p>I have measured the Noise Filter (DC29-00013A). Its input side is 121V and output side is 121V. The wall plug is 121V. At the same time, there is no any responses, or led lights on at all.</p>
<p>I am not sure if the Filter is good and working? do I need to replace it?</p>
<p>I have checked the water pump (inlet and outlet) and see nothing except water.</p>
<p>What else I should check? How can I know if the PCB (the main control board) is working or dead? There is no sign of burning on it or anywhere.</p>
<p>Please help. Thank you in advance!</p>
<p>⟐ Answered 4월 21, 2026 at 3:52 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/230882/Samsung+washer+no+power+at+all+suddently</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/230882</guid>
<pubDate>Tue, 21 Apr 2026 03:52:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: loud knocking on spin cycle]]></title>
<description><![CDATA[<p>Hello. When our samsung front load washer gets to the spin cycle it sounds like horses are galloping through the laundry room.  It is under warranty. They replaced shocks....just as bad or maybe even worse. If you are in the room it's so loud you can not hear a person talk beside you. I read a few of the other questions of similar nature on here but didn't see on where shocks had already been replaced and checked that not clothing or foreign objects in machine.  I video recorded the sound when I turn drum by hand. The bang happens when you move the drum so simple to reproduce the noise. The tech  seemed stumped so I thought I'd ask professionals online. Thank you for any ideas.</p>
<p>⟐ Commented 9월 01, 2025 at 12:26 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/282179/loud+knocking+on+spin+cycle</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/282179</guid>
<pubDate>Mon, 01 Sep 2025 12:26:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine: What does the error code 3E mean on my front loader washing machine?]]></title>
<description><![CDATA[<p><strong>Samsung wf1752wpc</strong></p>
<p>The error code 3E keeps showing up on the machine at the start of the cycle. It won’t spin or start a rinse cycle or anything. I run the machine on test mode and when I select either spin or rinse it comes up with the error. I took the motor out and checked the bushes and they are all fine, but when I remove the top of the washing machine and play around with the wire harnessing and making sure plugs are pushed all the way in (I don’t really feel like I do anything to them) it starts working again! I have done this twice now and then it will stop working again after 4 or 5 washes. I’m not sure what would be causing it but I’m hoping someone could help me narrow it down so I can get it fixed permanently without having to get a new machine. Cheers</p>
<p>⟐ Commented 11월 25, 2025 at 10:35 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/498491/What+does+the+error+code+3E+mean+on+my+front+loader+washing+machine</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/498491</guid>
<pubDate>Tue, 25 Nov 2025 10:35:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine: My front load washer isn't powering on - How to diagnose?]]></title>
<description><![CDATA[<p>My Samsung front load washer (wf0500nce) suddenly wouldn't turn on - press the power bottom and nothing happens - no lights, no life.</p>
<p>The outlet, the plug and the cable are all fine. I took out the door switch and tested it for continuity and that checked out (although i am not sure  if there being continuity means door switch is OK). I manually  depressed the spring loaded switch to simulate the door being closed but it still wouldn't turn on.</p>
<p>How do i go about finding the fault?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_06_09_Num_2017" class="header">Update (06/09/2017)</h3></div>
<p>Is this the fuse?:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/XlRlQtJ2JcjvSBFN.standard" width="282" height="211" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/XlRlQtJ2JcjvSBFN.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p><a href="https://i.imgur.com/LJde7hq.jpg" rel="nofollow noopener noreferrer">https://i.imgur.com/LJde7hq.jpg</a></p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/JdyKCBjbXMIBpYiw.standard" width="282" height="211" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/JdyKCBjbXMIBpYiw.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p><a href="https://i.imgur.com/s0NJOsd.jpg" rel="nofollow noopener noreferrer">https://i.imgur.com/s0NJOsd.jpg</a></p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_06_09_Num_2017_1" class="header">Update (06/09/2017)</h3></div>
<p>I don't see any fuse from noise filter to board. I do see what i think is the fuse in the board. I circled it in the picture. Sorry my phone's camera isnt the best.</p>
<p><a href="https://i.imgur.com/Bd2h65G.jpg" rel="nofollow noopener noreferrer">https://i.imgur.com/Bd2h65G.jpg</a></p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_06_09_Num_2017_2" class="header">Update (06/09/2017)</h3></div>
<p>Yes oldturkey03, I am not showing any voltage on the relay you marked in the picture above. No 125v, no 220v...just 0.</p>
<p>Do you think it could be the fuse at the board that's blown?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/V2lUH1JHclHYr41n.standard" width="282" height="163" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/V2lUH1JHclHYr41n.huge&quot;, '', 'width=1600,height=926')" /></div>
<p><a href="https://i.imgur.com/vhZvFZJ.jpg" rel="nofollow noopener noreferrer">https://i.imgur.com/vhZvFZJ.jpg</a></p>
<p>EDIT: Just found the diagrams:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/NA6NhnESXlamqBOO.standard" width="282" height="158" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/NA6NhnESXlamqBOO.full&quot;, '', 'width=1366,height=768')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/6DLpOfpZLdTA5BB5.standard" width="282" height="185" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/6DLpOfpZLdTA5BB5.full&quot;, '', 'width=1051,height=689')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/4MZQjYfYBkFttOLf.standard" width="282" height="166" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/4MZQjYfYBkFttOLf.full&quot;, '', 'width=1217,height=717')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/2UvTZRUXRI1HZUMG.standard" width="282" height="128" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/2UvTZRUXRI1HZUMG.full&quot;, '', 'width=1281,height=583')" /></div>
<p>⟐ Commented 5월 11, 2024 at 20:37 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/403946/My+front+load+washer+isn&#039;t+powering+on+-+How+to+diagnose</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/403946</guid>
<pubDate>Sat, 11 May 2024 20:37:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine: washing machine leaking water from coin trap]]></title>
<description><![CDATA[<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="3SjNrOQoJBhK43LJ" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/RLiZgRbZqRPIZYZx.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/3SjNrOQoJBhK43LJ_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="UdYZDttZqrCgheuE" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/1sgnSPudrGtKUBoR.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/UdYZDttZqrCgheuE_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<p>My 14 month old (warranty expired) front loader Samsung wf45k6500av/a2 is leaking water from around the drain pump filter cap during the whole cycle.</p>
<p>Do you think I just need a new drain pump filter cap or is there a bigger problem?</p>
<p>And yes, the filter is clean, nothing seems to be lodged in the tubes either.</p>
<p>⟐ Answer accepted 3월 31, 2026 at 6:13 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/492986/washing+machine+leaking+water+from+coin+trap</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/492986</guid>
<pubDate>Tue, 31 Mar 2026 06:13:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung washing machine wa50k8600av: Samsung WA51A5505AW with same unremovable 9C8 ERROR CODE]]></title>
<description><![CDATA[<p>I have a Samsung WA51A5505AW with same unremovable 9C8 ERROR CODE. Samsung help was no help, this washer is only 14 months old like new and I tried every YouTube and on line fix but nothing seems to remove the 9C8 code. Pasadena, Md</p>
<p>⟐ Answered 7월 16, 2024 at 15:38 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/832414/Samsung+WA51A5505AW+with+same+unremovable+9C8+ERROR+CODE</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/832414</guid>
<pubDate>Tue, 16 Jul 2024 15:38:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine WA456DRHDWR: Samsung washer - Stops mid-cycle]]></title>
<description><![CDATA[<p>This Samsung WA456DRHDWR AA Washing Machine is less than 3 years old and seems to be having massive failures.  It's a top-loader.  At first I was getting errors codes indicating that there was an issue with the water level sensor.  I replaced this part and no longer get  those codes.  But the washer continues to stop mid-cycle.  It seems to stop anytime it is trying to transition from one cycle stage to the next (from wash to rinse, or from rinse to spin).  If I stop the cycle and try to restart (or power it down then try), it will not restart at all.  The only way I have found to get it to restart is to unplug the machine  for an hour or more, then start over with whatever cycle I need at that point (full cycle, rinse and spin, or spin only).</p>
<p>I pulled the drain pump off and made sure nothing was stuck and it seems to be functioning correctly most times.  Also, the water inlet, door lock, etc all seem to be functioning correctly.    I am thinking that this is an issue with the control board and it will need to be replaced.</p>
<p>I am trying to find the easiest way to diagnose the control board since it is an expensive part.  Of course Samsung is completely useless in helping or making good on this issue which seems to be prevalent on other forums.</p>
<p>Any help would be greatly appreciated. Thanks in advance.</p>
<p>⟐ Answered 3월 23, 2024 at 9:24 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/262318/Samsung+washer+-+Stops+mid-cycle</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/262318</guid>
<pubDate>Sat, 23 Mar 2024 09:24:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine WA400PJHDWR: Samsung wa400pjhdwr/aa drain pump cover broke]]></title>
<description><![CDATA[<p>Drain pump cover broke and drain clamp let loose leaving entire load of laundry water everywhere.  I can easily replace.the drain pump cover; but I'm thinking that may be a symptom not the cause.  How can I tell if there is something else is wrong  that is the cause (like shocks if it has them) that needs to be replaced?  I note there Ppear to be 4 springs on the corners of the drum that I am guessing are shocks.  Several  have visible play (can move up and down at least an inch). No experience to know if that is normal.   Also - this is the second Samsung washer machine where I have had the clamp let loose.  Why do they use only a hand pinch compression clamp?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/fV3QAgqmDQnqJGqQ.standard" width="169" height="225" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/fV3QAgqmDQnqJGqQ.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/CSDCTZhoxZPShSAx.standard" width="282" height="211" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/CSDCTZhoxZPShSAx.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>⟐ Edited 1월 08, 2024 at 13:04 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/508955/Samsung+wa400pjhdwr-aa+drain+pump+cover+broke</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/508955</guid>
<pubDate>Mon, 08 Jan 2024 13:04:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine: Washing machine stops mid-cycle, resumes after some time]]></title>
<description><![CDATA[<p>Hello everyone, I've been experiencing this strange issue with my Samsung washing machine. Here's a summary. Whenever I start it, everything seems fine, the water is being pumped in and out, the drum spins in both directions and spin cycle works well. But, after some time, it just cuts off. It just stops emitting any signs of life. Unplugging it and plugging it back in doesn't do the trick either and it seems like an electrical fault. But after some time, usually half an hour to an hour, it just randomly springs back to life and continues where it left off and everything seems perfect again. Any idea on what could be the cause of this behavior? I doubt the lid switch or water inlet valve are causing this because those problems would persist even when the washer is working.</p>
<p>⟐ Answered 6월 04, 2026 at 19:23 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/792111/Washing+machine+stops+mid-cycle,+resumes+after+some+time</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/792111</guid>
<pubDate>Thu, 04 Jun 2026 19:23:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: Door ERROR during wash - interlock fault?]]></title>
<description><![CDATA[<div class="imageBox imageBox_center"><img src="https://guide-images.cdn.ifixit.com/igi/o2AsgrnVG4DS5BdF.standard" width="183" height="225" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/o2AsgrnVG4DS5BdF.full&quot;, '', 'width=650,height=800')" /></div>
<p>About a year ago (almost to the day!!!), I had a load of washing that I couldn't get out of my washer because the door wouldn't open. Upon investigation I found that the door interlock has burnt out. I'm not sure what the piece is called that connects to the interlock (connector block?), but it was badly burnt and slightly melted, although the 3 metal contacts were still intact. Some of the interlock was damaged too, so I bought a new interlock and fit it to the burnt connector and it has been fine since. But this evening during a wash, my machine started beeping to say there was a door error - that it wasn't closed. When I pushed on the door, I heard a buzzing noise and the lock icon was shown on the display, but when I tried to rerun the wash, it said the same error. I'm not sure what to do? Do I buy a new interlock, or is the connector the problem - if so are these replaceable too, or does it mean I need a new machine? :(</p>
<p>⟐ Answer accepted 1월 22, 2026 at 12:14 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/121530/Door+ERROR+during+wash+-+interlock+fault</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/121530</guid>
<pubDate>Thu, 22 Jan 2026 12:14:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine: Washer stops mid-cycle, won't run again until left alone for while]]></title>
<description><![CDATA[<p>Hello everyone!<br />I have been dealing with my samsung f500 washing machine (not the device listed in the title on ifixit, because my washer isn't featured on the list), which is pretty new (12 months old).<br />Basically, it will run flawlessly. Whatever wash I pick, it is happy and gets on with it. However, if I run another wash within 8-24 hours (it varies), the wash will stop somewhere near the beginning of the cycle, at a point where it has to spin. There, it will jerk a few times as if it's trying to spin and finally stop, with neither the timer ticking down, nor the cycle continuing. <br /><br />Any wash cycle, even a stopped one (as described above) will &quot;reset&quot; this arbitrary clock, meaning that it takes another long wait afterwards until the washer will wash again.<br /><br />This goes for every kind of cycle. Even if it successfully runs a spin and drain cycle - for example - it will stop during the next cottons cycle. <br /><br />I have tested all individual functions (filling, spinning, draining, etc.) separately using the diagnostic mode. I have cleaned and cleared every tube and part that I can access with basic household tools and determination. I have disconnected and reconnected all electronic parts and checked them for wear or obvious damage (none, since it's still very new).<br />And so, I am perplexed. None of the parts I thought might be the issue are showing any faults when run individually, and the machine does run fine every so often. However, sometimes I need to run two washes in a day, and that clearly causes it to be very upset.<br /><br />I appreciate anyone who might be able to share some insight. I don't know much about washers except what I've gathered with a few days' research online into common faults and scouring google and various forums for fixes.<br /><br />Have a great day!</p>
<p>⟐ Commented 8월 10, 2025 at 6:11 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/765384/Washer+stops+mid-cycle,+won&#039;t+run+again+until+left+alone+for+while</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/765384</guid>
<pubDate>Sun, 10 Aug 2025 06:11:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine: no power to drain pump - Samsung Washer WF448AAW/XAA]]></title>
<description><![CDATA[<p>I have the same exact issue with Samsung Washer WF448AAW/XAA</p>
<p>No power to drain the pump. If I provide 120v direct to pump, the machine completes the cycle</p>
<p>I suspect a relay as well, but not sure how to locate the correct one</p>
<p>⟐ Commented 8월 01, 2026 at 23:33 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/738618/no+power+to+drain+pump+-+Samsung+Washer+WF448AAW-XAA</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/738618</guid>
<pubDate>Sat, 01 Aug 2026 23:33:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine: Samsung no power model WW90554DAN with ad wash]]></title>
<description><![CDATA[<p>Please help, we changed the pc board and the transformer still no power on the display and not switching display on</p>
<p>⟐ Commented 3월 04, 2026 at 1:31 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/942945/Samsung+no+power+model+WW90554DAN+with+ad+wash</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/942945</guid>
<pubDate>Wed, 04 Mar 2026 01:31:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: Pourquoi j'ai de l'eau qui coule du bac de savon-adoucissant]]></title>
<description><![CDATA[<p>Lorsque la machine charge l’eau, l’eau déborde par le bac de savon-adoucissant<br />Au début du cycle, et avant le rinçage</p>
<p>Google translate:</p>
<p>Why do I have water flowing from the softener soap tub.</p>
<p>When the machine loads the water, the water overflows through the soap-softener tank At the start of the cycle, and before rinsing</p>
<p>⟐ Answered 3월 22, 2025 at 5:39 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/702548/Pourquoi+j&#039;ai+de+l&#039;eau+qui+coule+du+bac+de+savon-adoucissant</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/702548</guid>
<pubDate>Sat, 22 Mar 2025 05:39:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine: Washing machine drum is off balance how to fix it?]]></title>
<description><![CDATA[<p>Samsung WF42H5000AWA2 waking machine drum is off balance  how to fix it?The drum in my Samsung washer is making thumping noises and I'm also assuming the it is off balance as well. Can someone Please Help me?</p>
<p>⟐ Commented 11월 25, 2024 at 12:03 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/380805/Washing+machine+drum+is+off+balance+how+to+fix+it</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/380805</guid>
<pubDate>Mon, 25 Nov 2024 12:03:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Front Load Washer WF210ANWXAA: Machine will power up after a restart but will not start a cycle]]></title>
<description><![CDATA[<p>My washer would not power on but did so after several restart attempts. Now it will turn on but will not start a cycle. Door is tight ,child lock and delay start are not on.</p>
<p>⟐ Answer edited 9월 27, 2023 at 18:14 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/816131/Machine+will+power+up+after+a+restart+but+will+not+start+a+cycle</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/816131</guid>
<pubDate>Wed, 27 Sep 2023 18:14:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine WW6800K Series: SAMSUNG washing machine doesn't power up]]></title>
<description><![CDATA[<p>I have a washing machine that has stopped in the middle of a cycle and showed an 'UC' error. On the SAMSUNG's site it says that is <strong>is related to the excessive fluctuation of the power supply voltage</strong>. I turned it off and now it doesn't turn on anymore.<br /><br />Analyzing the main board, I've checked low voltage power supply and it seems to work, it outputs 37V (or something like that, I don't remember the exact value). On some connectors I've measured 5V and 12V.<br /><br />In the same board there is also a relay connected to the input that, when active, powers other components (like the door lock) and the main rectifier circuit that powers the inverter.<br />If I bypass that, the machine turns on and after a couple of seconds I can hear the relay activating. At this point I can remove the bypass and the machine stays on. (I haven't tried to run a cycle)<br /><br />At this point I'm not sure on what is the problem. The description of the error code makes me think that it has something that measures some kind of voltage? (I don't know what it checks and where), so maybe that is faulty? Or I'm missing something else?<br /><br />I've attached a simplified schematic  that I've drawn while trying to understand how it works.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/DDwhjDMluFaExK3h.standard" width="282" height="167" class="hasMenu hasLarge" alt="이미지" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/DDwhjDMluFaExK3h.full&quot;, '', 'width=1186,height=702')" /></div>
<p><br />Moreover, I've found a service manual online that have some details on the wirings: <a href="https://www.manualslib.com/manual/2797277/Samsung-Ww6000j-Series.html" rel="nofollow noopener noreferrer" title="https://www.manualslib.com/manual/2797277/Samsung-Ww6000j-Series.html" target="_blank">https://www.manualslib.com/manual/279727...</a></p>
<p>Do you have any suggestions? Thanks.</p>
<p>⟐ Edited 12월 28, 2023 at 10:06 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/800500/SAMSUNG+washing+machine+doesn&#039;t+power+up</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/800500</guid>
<pubDate>Thu, 28 Dec 2023 10:06:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine WA48H7400AW: WA48H7400AW/A2 not spinning during wash mode]]></title>
<description><![CDATA[<p>My Samsung WA48H7400AW/A2 makes loud noise s when it’s going through washing stage. It fills with water but I don’t see the clothes spinning or moves around in water during washing stage.  However it will spin to dry though. Please help</p>
<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="BkhXsXg13iTHJSdK" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/DqKQPRTTkADLYfDK.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/BkhXsXg13iTHJSdK_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<p>⟐ Edited 1월 08, 2024 at 12:34 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/750134/WA48H7400AW-A2+not+spinning+during+wash+mode</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/750134</guid>
<pubDate>Mon, 08 Jan 2024 12:34:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung Washing Machine WA40J3000AW: Clothes still wet after spin cycle]]></title>
<description><![CDATA[<p>WA40J3000AW/A2 Top load Samsung washing machine will get stuck on the spin cycle and will leave the clothes wet. Sometimes taking out a few articles of clothing and restarting will allow the washer to complete the spin cycle. However this issues seems to be getting worse and worse.</p>
<p>We went to Lowes to see if we could get someone to check on our washer but they said it would be cheaper to buy a whole new washer. I want to try my hand at fixing it before I resort to that. Does anyone have any ideas on a potential solution?</p>
<p>⟐ Edited 1월 08, 2024 at 12:37 GMT-7</p>]]></description>
<link>https://ko.ifixit.com/Answers/View/596494/Clothes+still+wet+after+spin+cycle</link>
<guid isPermaLink="false" >https://ko.ifixit.com/Answers/View/596494</guid>
<pubDate>Mon, 08 Jan 2024 12:37:22 -0700</pubDate>
</item>
</channel>
</rss>
