주요 콘텐츠로 건너뛰기
13" 알루미늄 unibody, 2.0 또는 2.4 GHz Core 2 Duo 프로세서.
574 질문 전체 보기
질문 마감됨
Why does my MacBook freeze after I first log in?
After the first 1-2 mins of logging in, it freezes immediately. The entire screen freezes as well as the mouse. When I try to shut it down or restart it, I am not able to hit the return button or use the pad. I just received it as a gift yesterday and the giver does not have a receipt.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Cindy - Sounds like your system was used. Is that correct? If so your system is looking for a network resource to log into. If you let it run for a a while it should allow you access at which point you should be able correct the problem. Let us know and we can review what to do next.
If you believe you have a new system, your the system has a date code as part of its serial number so you still should be able to bring it into an Apple Store for them to fix the problem (if you have a hardware issue).
I would recommend getting an extended Apple Care service plan if the warranty period is better than 1/2 over just for peace of mind.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 777
