주요 콘텐츠로 건너뛰기
Unibody가 아닌 Core Duo & Core 2 Duo 프로세서
375 질문 전체 보기
Won`t burn DVD/CD. Trouble reading CD , not music DVD
Memory : 4 GB 667 Mhz DDR2 SDRAM
MATSHITA DVD-R UJ-875.
1) New Music CD `s : throws it out! Old CD music throws it out! Same CD`s works ok with normal CD player.
2) Music DVD play well! Strange!
3) Software : Simply Burn version 428.
Find the DVD (for example Verbatim 8X DVD+ R DL). Says 7.96 free. ) Starts burning. It stops. Says finished.
4) Packard DVD-R 1-4x Speed, 4,7 GB. Throws it out.
4) Check with disk tool : says MATSHITA is ok.
5) Can I repair ?
6) Buy a new internal DVD driver ?
7) Difficut to change?
8) Will not take CD Laser Lens Cleaner (Dry System). It Used to do that some time ago.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Replacing an optical drive is a moderately difficult DIY task. AFIK there are no DIY repairs for a damaged optical drive.
If this answer was helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
It is common for SuperDrives to stop reading certain discs while reading others perfectly. This is due to CDs and DVDs using different lasers. In my experience, replacing the drive is the most reliable way to fix this issue. It is moderately difficult for an inexperienced technician, but for a seasoned technician it should be a fairly easy replacement. The SuperDrive suggested by machead3 is incorrect, that is for the late 2008 and later. The A1261 uses a 12.7mm PATA SuperDrive. A link to the replacement steps are here
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Tom Lasse 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,558
