Depends on the age of your Macbook:
Resetting the SMC on Mac portables with a battery you can remove
1. Shut down the computer.
2. Disconnect the MagSafe power adapter from the computer, if it's connected.
3. Remove the battery.
4. Press and hold the power button for 5 seconds.
5. Release the power button.
6. Reconnect the battery and MagSafe power adapter.
7. Press the power button to turn on the computer.
Resetting the SMC on portables with a battery you should not remove on your own
2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
3. On the built-in keyboard, '''press the (left side) Shift-Control-Option keys and the power button at the same time.
4. Release all the keys and the power button at the same time.'''
5. Press the power button to turn on the computer.
Note: The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
If this answer was helpful please remember to return and mark it Accepted.
댓글 3개
So when i tryed first option. It didnt reset. My adapter is blinking green orange. My battery can be removed but ive tried to reset smc 100 times now and to now affect
Andre Battle 의
Tried countless times and finally SMC reset worked, not really sure what I did differently
Katherine 의
I have a MAC PRO 3,1 8-Core that all USB ports stopped working, I tried the SMC reset, and it does not work, PRAM and NVRAM reset dont work since the USB ports don't work, I dont have a wireless keyboard or mouse (bluetooth), and even if I had I cant configure them since I cannot use the mouse or Keyboard. so basically stuck. Im really frustrated, could this be a logic board issue?
kevedosdesert 의
