모델 A1286. 2011년 2월 출시 / 2.0, 2.2, 또는 2.3 GHz 쿼드-코어 Intel Core i7 프로세서
540 질문 전체 보기
logic board water damage repair; battery
I’m attempting to repair a water damaged 15" MacBook Pro, unibody early 2011. I've already tried cleaning the corroded areas with rubbing alcohol, with no success. next I was going to try a replacement logic board. if that doesn't work i am going to give up on the project. my question is this: the battery may also be fried, so I don't want to try out a new logic board with the battery in; and I don't want to bother with buying a new battery if the computer isn't going to work. will the macbook power up with the battery removed, and just the power adapter plugged in? will ifixit accept a return on the replacement logic board if the macbook still won't work?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
This is the volunteer DIY help forum for assurances from iFixit contact them. Yes if the DC-in board is not damaged the machine will start without a battery.
If this answer was helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
cameronkroeger 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,078
