주요 콘텐츠로 건너뛰기
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 질문 전체 보기
How do I reset a frozen screen on my razr?
I was in a call, & when I tried to end it, my phone froze. Now it is stuck with the call display still showing, and it won't let me do anything. I can't turn it off, and with no battery to take out, I have no idea how to reset it.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 1개
my razer cannt switch on.. only after the razer logo out then its off again.. helep helepp
댓글 달기
답변 13개
선택된 답변
I would suggest removing the battery for a few minutes. It's not the most difficult thing to get to.
Motorola Droid RAZR Battery Replacement
You don't need to actually remove the battery, just unplug the terminal for a few minutes.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
My phone is not working after battery replacement and stopping on Intel what I have to do please help
댓글 달기
가장 유용한 답변
My phone did the EXACT same thing. This is the fix that worked for me since the Razr doesn't allow you to take the battery out:
Hold the volume DOWN button + Power Button down at the same time for 10-15 seconds and the phone will power off. It might just restart. If it doesn't, wait 20 seconds then power it back on.
VOLUME DOWN BUTTON + POWER BUTTON held down at the same time for 10-15 seconds. This will power the phone down. Then you can turn it back on!!
해당 답변은 도움이 되었습니까?
점수 25
댓글 18개:
Thanks so much! It worked!!!
Worked for me too! Thank you!
It worked for me too. Thanks for this very helpful information.
Great Advice!!!!!!!!! It worked!
I was in a panic!! This worked!!!
댓글 13개 더보기
댓글 달기
Yay! Thank you for the advice of Volume Down & Power at same time for 15 seconds, it worked!!!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
yes this was the only thing that worked for me thanks.
댓글 달기
hold volumn down + power button together worked for me to. thank you
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Just worked for me too! thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
don't take your battery out voids the warenty power + volum down works
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Omg you're amazing, was about to bring my droid razr into Verizon because nothing worked and it's been frozen since yesterday, but this simple trick worked! Thanks!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Does not work all of the time. First, just to get the Motorolla icon to appear can take 20 attempts. Then, most people are afraid that a complete restore will him to lose all files - does not happen with my Iphone - so he is left with turning it off, then if on again, same problem. Also, his requires to hold onto power button once green light comes on to get to any menu. Solution - get an Iphone.
Worked great for me. It only took once, not twenty. Didn't lose any files.
댓글 달기
wow - genius! thanks! I was about to head to Verizon also!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!I was also about to take it to verizon because nothing worked including holding down the power button...holding the volune down at the same as the power worked! Much appreciated :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I did that. But everytime I turn it back on it freezes turning on and its been like this for two days now. What do I do now.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
thumbs up !!!!!!!! bravo !!!!!!! it worked, by pushing volume down + power button at the same time. great........ mir of pakistan
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My Motorola Razr is not working. When it restarts it just frozen into a Red Screen and not move forward to Home-screen and remains the same for the rest of time.
What should I do to recover it.
Thanks....
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i have the same problem My Motorola Droid Razr is not working. When it restarts it just frozen into a Red Screen and not move forward to Home-screen and remains the same for the rest of time.
Kindly guide....
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
susyq 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 40
전체 시간: 27,994
