주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2201 질문 전체 보기
iPhone thinks there is a sim, when there isn't?
Hi, I just repaired my iPhone screen, and I have done a few before with no trouble, but this time once I had put it back together, it is always searching for reception, but never finds it.
I tried restarting, taking the sim out etc but even without a sim, it doesn't say 'no sim' it still says searching.
Can anyone tell me what is going wrong and how to fix it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 4개
선택된 답변
Not totally a apple head here but i do know the iphone 4s has GSM (sim card) and CDMA cellular. i think this plays a role in this.
check your phone settings, And or a restore.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Set the date and time manually to the correct values and then restart your phone. Worked for me :)
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I've got the same problem.. No one with a helpfull answer for this? Please
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Well, found a solution to this problem.
After changing three screens on iPhone 4S with iOS6. All three with this problem.
The solution I found: Insert the sim before you turn on the phone. Then connect the iPhone to the WiFi. Take the sim card out, and put if back in ;)
Hopefully this will resolve the problem.
댓글 달기
Your problem could come from 3 sources.
The first one is a software problem: just try to make restore with iTunes.
The second one could come from the sim reader commutator. If this commutator doesn't make contact, the iPhone will think that there is a sim in your slot. So you have to join them together. And after, you have to check if it's separates when you put your trap inside.
The third one is: you haven't properly plugged your antenna cable on the antenna connector.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you so much for the second option, I know it's a very late reply, but this helped me SO much. After getting water in my iPhone 6, I thought the SIM slot had stopped working! Thank goodness for this otherwise I would've thought I needed to desolder and resolder things to fix it! It finally recognized when the SIM was and was not in the slot. Thank you so much!
댓글 달기
귀하의 답변을 추가하세요
Ben 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 6,783
