Smaller, thinner, quieter model of the Playstation 2 (SCPH-7XXXX) released by Sony in September, 2004.
44 질문 전체 보기
PS2 slimline no power.
Accidentally inserted wrong power adapter into PS2 Slimline, now I have no power. Is there a fuse or some other component that I have to or can replace inside to get it working again?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글:
Most likely happened is that it powered on and soon after a capacitor or circuit got fried.
if this is true was there any smoke or the smell of something burnt?
의 답변
Hi oldturkey there was no smoke or smell, the device just simply failed to start. For this reason is why I thought that there might be a protective fuse.
의 답변
의견 추가하세요
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
John, attached image will show you all the fuses on your logic board. Use a multimeter to check for continuity of those fuses. Pay particular interest to the resettable fuses. Of course, look for any charred, burned, or missing component as well. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Cheers for the diagram oldturkey and thanks for the help
의 답변
you are welcome, good luck.
의 답변
Stupid question, how do you reset the fuses??
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
John 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 15
지난 30일: 58
전체 시간: 6,221
