주요 콘텐츠로 건너뛰기
The HTC Evo Shift 4G is a smartphone marketed as the concurrent/sequel to Sprint's flagship Android smartphone.
1 질문 전체 보기
My touch screen doesn't always function.
My HTC Evo shift works only 1/3 of the time. The other time, the touchscreen either freezes up so I can't make choices or it will make decisions by itself, such as to open the menu and select an option. It also likes to open an options panel while I am texting someone and call them instead.
It is out of my control! I brought it in to Sprint and they said I could replace the screen for $35, but I'm not sure the screen is the problem.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Well Miss Stabenow, the LCD may not be the problem, but the digitizer,(The part that give your phone its touch screen capabilities) may be the problem. That's why Sprint wanted to replace it. First try to give your phone a hard reboot. If that doesn't work, then you may want to get your digitizer replaced. But tell sprint you only want the DIGITIZER replaced only, not the whole display assembly. Hope I helped and happy repairing.
MacManiac
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Kimberly Stabenow 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,076
