주요 콘텐츠로 건너뛰기
모델 A1103 / 1.25, 1.33, 1.42, 또는 1.5 GHz G4 프로세서
20 질문 전체 보기
Can't install operating system on my Mac mini new hard drive?
I just installed a new hard drive on my mac mini G4 and now I cant install the os, either 9 or os X. I have the disks.
Thanks for any help.
Cordially Jim
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
Start from the Installation disk by holding the "C" key down. On the second screen the pull down menus will appear at the top of the screen. Go to Utilities. Pull down to "Disk Utility" and format the drive. OSX extended journaled will be fine. Now you can continue with the system installation. When finished reboot from the hard drive and go under the apple in the upper left hand corner to "software update". Download and install the updates. Repeat this till there are no more updates. That's it.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
What you need to do is insert the OS X install disk into the optical drive and hold 'C' while starting up. This will boot from the install disk, which will walk you through the process of installing OS X.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have a g4 mac mini. I have tried to install morphos. I held down the c key. But instead of installing. I get a ↻and ↦ symbols what do it means
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jim 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 7,106
