주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
Why won't my 32GB CF card work?
I've got an iPod Classic 80 GB model that won't boot when I perform a compact flash conversion using this part:
http://www.dealextreme.com/details.dx/sk...
or this part:
The CF card is good, as I've swapped it with the one working fine in my upgraded 32GB iPod mini.
Can anybody recommend an adapter that works for this upgrade, or perhaps explain why I may be barking up the wrong tree?
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 7개
Yeah. Should have mentioned that. I tried formatting it both in HFS+, which I've read works best if you're primarily a Mac user, and in Fat, which I read works best with windows. No luck either way.
Yeah. And just to be sure, I tried it both ways.
Hmm... Can you put the original hard drive back into it, and see if it will work then?
Nope. Original hard drive was kaput, which was why it was for sale. I may have a line on another broken one of the same line. That should tell me if it's an adapter issue, or if there is more substantial trouble with the iPod.
If it can't read it, then I would have to conclude that the adaptor is bad. Can you boot it into disk mode, or diagnostic mode?
댓글 2개 더보기
댓글 달기
답변 2개
선택된 답변
did you format it with the right scheme? i believe they these use the FAT filesystem.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Did you put the ZIF cable in facing the right way?
댓글 달기
가장 유용한 답변
Hi,
i used the first adapter with an 1GB CF-Card to give it a try and it worked fine. I didn't used a special format and let it up to iTunes to format the card. Maybe its a problem with the compability between the adapter and the card.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Joseph Manning 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 13
전체 시간: 5,406
