주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
399 질문 전체 보기
Liquid Damage, Keyboard Trackpad only work "option" key selections?
I find this a little weird so I was hoping someone could shed some light.
After my macbook pro had liquid damage the keyboard and trackpad will not work when the computer boots into it's primary or recovery partitions.
They will work, however, when holding down the option key and having my boot options come up. After I select a boot partition they no longer work.
USB keyboard and mouse do work when booted.
Any insight??? I know my way around but this doesn't make sense to me.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
You need to open your system and clean your trackpad & keyboard. You'll need to take the system fully apart Upper case teardown Then you will need to disassemble the keyboard it's self. Here's a vid on the process to 15" key board teardown
The other option is replacing the upper case/keyboard assembly.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
You spilled liquid onto/into your keyboard and you'r puzzled it doesn't work- electronics and liquid do not mix. That, by chance, the only key that works is the option key is unusual but not a sign that the rest of the keyboard is good. Replace your keyboard all will be well until corrosion does more damage.
If this answer was helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
epicwake 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,143
