주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
794 질문 전체 보기
Battery model number MacBook Pro 13 inch 2010
I was wondering; how can I determine the model number of the battery used in the Macbook Pro 13" 2010? preferable without opening up my laptop..
I plan to order a new battery online (from a non apple store) but for that I need the model number.
Grtz
Ruud van der Salm
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 답변
Here is a link to the ifixit part number of the battery and a video showing how to replace it. Good luck.
[연계 제품이 누락 또는 비활성화 됨: IF163-019]
Note the Apple part number is 661-5557.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
I just meant the model number of the battery, where can I find it?. I know how to assemble it :) It's not tracable through Mac OSX. Do i have to look at my battery for this? Or is there an easy way of telling the model number (I want to order a new one from a 3rd party reseller)?
댓글 달기
@ Ruud van der Salm did you get a way to find it ? Mine is a Macbook Pro 2009 (Core 2 Duo) model. I ran the 'System Profiler' application, but could find only the following information. The battery model wasn't listed there.
Battery Information:
Model Information:
Serial Number:
9
Manufacturer: DP
Device name: bq20z451
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 0003
Hardware Revision: 0002
Cell Revision: 0100
Charge Information:
Charge remaining (mAh): 472
Fully charged: Yes
Charging: No
Full charge capacity (mAh): 472
Health Information:
Cycle count: 1343
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): 198
Voltage (mV): 12495
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 180
Disk Sleep Timer (Minutes): 0
Display Sleep Timer (Minutes): 180
Wake On AC Change: No
Wake On Clamshell Open: Yes
Wake On LAN: Yes
Current Power Source: Yes
Display Sleep Uses Dim: Yes
Battery Power:
System Sleep Timer (Minutes): 60
Display Sleep Timer (Minutes): 60
Reduce Brightness: Yes
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 60
Revision: 0x0000
Family: 0x0085
Serial Number: 0x000c47a5
Charging: No
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
There is no battery number, but I was looking for SN of battery and found that solution. So marked answer as helpful. Sorry for off-topic.
댓글 달기
Model number of your Battery is A1332 . I went through the same process to find it and get it replaced.
hope it helps.
A
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
댓글 달기
hi , i need help in know my battery number this is the below of my macbook pro info bought 2010
Languages
MacBook Pro (13-inch, Mid 2010) - Technical Specifications
Size and weight
Height:
0.95 inch (2.41 cm)
Width:
12.78 inches (32.5 cm)
Depth:
8.94 inches (22.7 cm)
Weight:
4.5 pounds (2.04 kg)1
Connections and expansion
MagSafe power port
Gigabit Ethernet port
One FireWire 800 port (up to 800 Mbps)
Mini DisplayPort
Two USB 2.0 ports (up to 480 Mbps)
SD card slot
Audio in/out
Kensington lock slot
Communications
AirPort Extreme Wi-Fi wireless networking2 (based on IEEE 802.11n specification); IEEE 802.11a/b/g compatible
Bluetooth 2.1 + EDR (Enhanced Data Rate) wireless technology
10/100/1000BASE-T Gigabit Ethernet (RJ-45 connector)
Audio
Stereo speakers with subwoofers
Omnidirectional microphone
Combined headphone/line in (supports digital output)
Support for Apple iPhone headset with microphone
Environmental Status Report
MacBook Pro is designed with the following features to reduce its environmental impact:
Highly recyclable aluminum and glass enclosure
Mercury-free LED-backlit display
Arsenic-free display glass
BFR-free
PVC-free3
Reduced packaging volume
Meets ENERGY STAR Version 5.0 requirements
Rated EPEAT Gold4
it doesnt say battery number help please
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ruud van der Salm 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 27,064
