Model No. A1367 / 8, 16, 32, or 64 GB capacity
1293 질문 전체 보기
iPod not charging / charging port problem
Having truble with the charging port. at first i would move it around and it would charge but now it stop. i looked around to see if i find any videos on this but haven't found any. Please Help!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
tioiggy, here is my answer from a similar question "You will of course have to totally disassemble the iPod. The dock connector is solder onto the board. You will have to do lots of soldering. You will have to un-solder two anchors and about 30 connections, they are very small and close to each other. So you have to take extra care not to shorten the pins out. After that you will have to resolder all those connections and the two anchors. Not an easy task, unless you are used to soldering small pieces. This video will give you an idea what you are up against. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
tioiggy 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 2,484
