cant hear from head phones or iPod holder.
ipod-30gb( cant hear anything with or without head phones)..
좋은 질문 입니까?
좋은 질문 입니까?
kwame, here is my answer form a similar question "here is my answer from a very similar question"this particular model has a problem with an IC on the logic board. You can try and see if you get sounds by applying some pressure to the right lower side of the iPod, almost between the click wheel and the bottom corner. Here is a forum that explains that http://discussions.apple.com/thread.jspa... and check for a posting by IPOD_wrecker. If that is happening to you there are only a couple of options. New logic board from about $40 on eBay, reflow your old logic board or you can try what warnergt did on http://forums.macnn.com/103/ipod-iphone-... it is kind of crude but it does seem to work. The reason why it works after you place it in the fridge, is that the contraction of the metal closes the micro crack in the solder joint. " The only other thing you could check is the head phone jack to see if it is stuck. Insert and remove the headphones a couple of times to see if that can get the jack unstuck. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 657
댓글 1개
let me know if this is the right iPod:-)
oldturkey03 의
