주요 콘텐츠로 건너뛰기
Netbook released 2011. Powered by Windows 7 Starter. Identified by model number 1018P-PU17-BK.
3 질문 전체 보기
DC power jack pin repair
The power pin on the DC jack has been loose and will not charge my battery. Is there a way to fix the pin so that the plug will transfer current, without getting a replacement?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
Rishi, the only way you can fix it properly is by replacing the jack. You do want to make sure that it is still properly soldered onto the mother board. If it is loose, you may solder it back on, if it is the jack itself, you will have to replace it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Rishi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,638
